Ford 9 in the C4
Old Jul 19, 2017 | 05:10 AM
Svante's Avatar
Svante
Default Ford 9 in the C4
Hi, today i began cutting away the brackets on the old Lincoln 9" i got my hands on and placed it under the Vette. It looks like the first thing to do is to cut the storage floor behind the seats to make room for the housing.
or is there any other solution i haven´t thought of?
Another thing! What center section and diff do you recommend? I was looking at Strange aluminium bolt through with 31 spline axles. Looks like a nice piece.
/Svante.
Old Jul 19, 2017 | 05:38 AM
bfit's Avatar
bfit
You could consider using a Dutchman housing and keep the IRS
It would need some fabrication to keep the geometry correct .
Worth a look at
Old Jul 19, 2017 | 05:50 AM
Svante's Avatar
Svante
Worth a look at
Looks nice, but the whole idea was to go solid rear 4-link. This will require some fabrication as well but i dont think it´s impossible.
/Svante.
Old Jul 19, 2017 | 02:53 PM
cv67's Avatar
cv67
St. Jude Donor '05
Woulda been nice if GM offered the solid axle as an option!
IRS sucks for drag racing, whats the rest of your plans for the car (Trans motor etc)
Old Jul 19, 2017 | 03:13 PM
Svante's Avatar
Svante
Yes i agree. The car has a fully built Lm7 with twin BW S366 turbos. And a ZF 6spd transmisson from a Bmw. I dont know how well the tranny will perform yet since it's new to this setup but i know a lot of guys who have put some serious power thrugh them.
I'll just have to see when i'm finished with the rear end i guess
/Svante
Old Jul 19, 2017 | 09:24 PM
383vett's Avatar
383vett
A Ford 9" will require opening up the rear floor for clearance. I have a friend who installed on in his Calloway aerobody. He didn't want to cut the floor so his car is jacked up. I had to cut a cover my floor slightly with my 12 bolt. Needed an inch or so of clearance.
Old Jul 20, 2017 | 01:03 AM
Svante's Avatar
Svante
great info, thanks!
I dont mind cutting the floor, i thought i just make an aluminium cover with proper clearance after.
/Svante
Old Jul 20, 2017 | 01:13 AM
383vett's Avatar
383vett
Originally Posted by Svante
great info, thanks!
/Svante
My car beat you to it.
Old Jul 20, 2017 | 08:47 AM
STEVEN13's Avatar
STEVEN13
/Svante.
Hi Svante,
Not sure what year you have. But on my 92 it has ABS and may be different. The passenger side was trimmed for the exhaust. However, I will be removing it as to clean up the underside of the floor. To get the car to sit low (as you know) the floor will need to be removed or trimmed. My floor is removable to access the center section.
I am using the Strange aluminium bolt through (I think its called Pro Case?). I am running 35 spline axles-But would not recommend them. As you would be limited to a few locker type of differentials which are noisy, clicks, and bangs. I removed the locker and switched to a spool (not the wise choice for the street-LOL). The 31 spline can run a LSD, Detroit Locker, and others.
I have a new PC and don't have access to my photos (yet).
Good luck with the build!
Steve
Just added 2 photos next post
Last edited by STEVEN13; Jul 20, 2017 at 08:56 AM. Reason: Just added 2 photos next post
Old Jul 20, 2017 | 08:55 AM
STEVEN13's Avatar
STEVEN13
Old Jul 20, 2017 | 09:31 AM
_ski_dwn_it's Avatar
_ski_dwn_it
/Svante.
No need to hack the car apart to install a solid axle. I can provide you with a complete setup, matched shocks, and springs - everything will bolt in and no nasty cross-member that WILL screw up your exhaust and ground clearance.
Simply bolt the setup in within a days time. GO racings and never worry about it again. Have built MANY of them and can give you people for reference that are running it today.
My car with a 434CI motor went 1.24 60ft times!
Give me a ring at 814.594.2357
Old Jul 20, 2017 | 02:54 PM
rklessdriver's Avatar
rklessdriver
Contact Quick Performance for a complete center section... and any/everything else you need for the 9". Ask to speak with Brydon.
http://www.quickperformance.com/Comp...ons_c_558.html
I run their Yukon Thru Bolt with a 35 spline spool in my 84.
Will
Old Aug 9, 2017 | 05:34 PM
Robban_C's Avatar
Robban_C
... IRS sucks for drag racing, ...
Why?
Old May 19, 2026 | 12:28 PM
morleybuilds's Avatar
morleybuilds
1st Gear
Default Would love to talk about this build
I am doing a 9”‘swap in my 84 vette and would love any direction or knowledge you still have appreciate your time
@_ski_dwn_it
QUOTE=_ski_dwn_it;1595183330]No need to hack the car apart to install a solid axle. I can provide you with a complete setup, matched shocks, and springs - everything will bolt in and no nasty cross-member that WILL screw up your exhaust and ground clearance.
Give me a ring at 814.594.2357[/QUOTE]
Old May 19, 2026 | 01:30 PM
_ski_dwn_it
@_ski_dwn_it
[/QUOTE]
Get in touch I can assist
To Ford 9 in the C4
