No electrical power
Old Jul 20, 2017 | 11:04 AM
mak89c4's Avatar
mak89c4
1st Gear
Default No electrical power
'89 C-4 Corvette: 47K miles, has been babied. Drove for about an hour yesterday, ran great. But was 100 degree day and as usual ran 'hot' (225/230 degrees) in stop and go city traffic. Pulled into driveway at home shut down car. Came out to restart car 30 minutes later - NOTHING. No dash lights, no lights under hood when hood lifted, nothing.
So obviously, no crank when key turned? Battery is good, cables good, connections good. Haven't started taking apart VATS ignition switch yet. Has never happened before. Any ideas would be appreciated.
Old Jul 20, 2017 | 11:18 AM
MikeP84's Avatar
MikeP84
I haven't look at an 89 before but with my 84 all the power runs down to the starter and that is the power distribution point. I have had those wires melt before I have lost my heads lights. Have you checked these wires? As far as the VATS I thought it was just a starter interrupter and doesn't effect power to different systems.
hcbph's Avatar
hcbph
Forget the VATS system, you'd have some electrical with or without a VATS issue for things like headlights and dash. I'd start at the battery and cables. If you have 'nothing', I'd first CONFIRM (I know you said it was good but this sounds too fishy to exclude) the battery is good then start tracing cables. Even if you had one of the ballast resistors blown you still should have something that would power up which you said the car was totally dead.
Time for the multi-meter to come out and be put to use. Based on 'everything' dead, I'd check the ground cable from the block to the battery first. I believe that's the single cable that has no alternate route to it. The positive has the main going to the starter but there's the pigtail that goes down below the battery to the stud with the ballast resistors on it. Don't forget those ballast resistors, even though they're hidden they could have issues thought I would not think all would die at the same time.
Hope that helps. Good luck
Old Jul 20, 2017 | 11:19 AM
s carter's Avatar
s carter
Define Battery good putting a volt meter across the Battery is not a foolproof test, From what your describing is NOT A VATS PROBLEM.
Have you tried to Jump start from another car, Living in Florida I have had Battery's start in the driveway and not Start at the ATM 5 Min. later Stone dead
If the jump start works, pull the battery cables inspect reinstall if it works great if not have Battery load test and replaced if needed.
Old Jul 20, 2017 | 11:36 AM
MikeP84's Avatar
MikeP84
The battery to block ground should be just above your oil filter. You can pull that battery out and go to your local auto parts store to have them test it for free and be 100% sure its good. A battery can look good with a volt meter test but as soon as load is put on it, it falls flat on its face.
Old Jul 20, 2017 | 02:04 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Yes.
To No electrical power
