It runs.......
Old Oct 3, 2002 | 01:52 PM
  #41
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
Default Re: It runs....... (Mr. Magoo)
Way to go. I think the moderators should give you some points for doing all that work so quickly. I know you'll have the bugs out in no time. Congrats. :cheers:
Old Oct 3, 2002 | 02:39 PM
  #42
vettmech's Avatar
vettmech
Default Re: It runs....... (joecaver)
HHHHHHhhhhhhhhmmmmmm....... I went all the way to the end of this to see a picture of it.............. :p: :seeya
Old Oct 4, 2002 | 06:47 PM
  #43
scorp508's Avatar
scorp508
Update.
1. Fixed the alternator situation. It was actually Fusible Link C that blew out because of a loose wire shorting out over at the starter. Charging great now.
2. Overdrive is working, apparently it just wouldn't engage when the charging system went out before. Not sure why, but I'm not complaining now. :D
3. Going to deal with the rockers and exhaust tomorrow morning. :D :D
Old Oct 4, 2002 | 07:25 PM
  #44
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re: (scorp508)
Glad to hear it....hope it all runs even better after the last few adjustments tomorrow.
:cheers:
Old Oct 4, 2002 | 08:11 PM
  #45
tarheelracer's Avatar
tarheelracer
Default Re: It runs....... (Scott94C4)
Oh and just think of how much easier and quicker it will be to do the second time. :D
What sucks is that this was the second time :(
Old Oct 4, 2002 | 09:40 PM
  #46
CSM87's Avatar
CSM87
Default Re: It runs....... (tarheelracer)
:cheers: :cheers: :cheers:
Old Oct 5, 2002 | 09:43 PM
  #47
vert2go89's Avatar
vert2go89
Cruise-In I Veteran
Default Re: It runs....... (93LT1)
sounds to me like you might have lost a ground and so the alternator went full charge from the voltage regulator going bezerk.
Old Oct 5, 2002 | 09:46 PM
  #48
vert2go89's Avatar
vert2go89
Cruise-In I Veteran
Default Re: It runs....... (vert2go89)
did I miss the thread or haven't you told what engine you put into your vette yet scorp?
Old Oct 6, 2002 | 01:37 PM
  #49
scorp508's Avatar
scorp508
Went to the dyno yesterday, but could not tune it. :( The dyno shop couldn't get a "real" wideband O2 reading for some reason on my car. They think there might be an exhaust leak somewhere introducing more air into the exhaust.
Old Oct 6, 2002 | 01:39 PM
  #50
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
I'm not sure if that wideband was operating correctly. I find it hard to believe that ALL of our cars were lean.
Old Oct 6, 2002 | 01:45 PM
  #51
scorp508's Avatar
scorp508
The mustang that came in after us screwed their sensor straight into their headers and it looked like it was working for them using that method. I dunno. :(
Old Oct 6, 2002 | 02:16 PM
  #52
Mervz's Avatar
Mervz
Cruise-In V Veteran
Cruise-In VI Veteran
I should have had Dean run the o on my car just to see what it said... :)
Old Oct 9, 2002 | 04:20 PM
  #53
DanielW's Avatar
DanielW
St. Jude Donor '04-'05-'06-'07-'08
Default Re: (Mervz)
2 more days :cry
Old Oct 9, 2002 | 04:27 PM
  #54
TrplBlk01's Avatar
TrplBlk01
Default Re: It runs....... (chucks88)
Congrats :cheers: :smash:
Old Oct 9, 2002 | 04:31 PM
  #55
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VII Veteran
Default Re: It runs....... (scorp508)
:cool: :cheers:
Old Oct 9, 2002 | 04:42 PM
  #56
James94LT1's Avatar
James94LT1
Default Re: It runs....... (Ericthewolf)
Work has been killing me lately so I think I have missed something here!
Whats the new stats on your motor Scorp? Man you got it running fast!
:cheers:
Old Oct 9, 2002 | 04:53 PM
  #57
SloRvette's Avatar
SloRvette
They tried clamping the probe onto the Mustangs muffler. At around 8000 rpm it blew the probe half way across the room and the vice grips out of the building. It was working properly.
It was working right on my car, Grubby's, and John's. A new probe and sensor didn't make a difference with Brian's.
Looking at your graphs George, I'd put my money on it working properly. Brian's acted like there was an exhuast leak ahead of the sensor, but the motor was down on power compared to the previous time. Ken's didn't respond to the FP regulator and from the sound of the test he did after I'd think either the pump or regulator isn't working right.
