starter change with headers
Old Oct 3, 2002 | 01:45 AM
lemans396's Avatar
lemans396
Default starter change with headers
My starter is done with. Thinking of changing it myself. I have hooker supercomps on. Will the starter comeout? Do I have to take the headers off? Also what's a good aftermarket starter in case I decide to go with something otherthan GM. Thanks
Old Oct 3, 2002 | 11:42 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: starter change with headers (lemans396)
The headers (hooker 2151's) on my car don't interfere with the starter at all, however I'm an LT1 so it could be different.
Old Oct 3, 2002 | 02:22 PM
vettmech's Avatar
vettmech
Default Re: starter change with headers (Nathan Plemons)
I'm not sure how your headers look but it has been a common prob with SBCs forever that we had to at least LOOSEN the right side header to get it out. I would rebuild the starter that you have instead of replacing it ..... unless it has solder coming out of the armature or the feilds are burnt up...... Everything else can be repaired easily and cheap. :seeya
Old Oct 3, 2002 | 02:24 PM
scorp508's Avatar
scorp508
I was looking at this while dismantling mine. Looks like you have to loosen the header at least. Also on auto cars the cooling lines run right under the starter, those sure won't be helping the situation.
Old Oct 4, 2002 | 01:23 AM
lemans396's Avatar
lemans396
Default Re: (scorp508)
Great.. :( Iwas hoping to avoid loosening 8 year old headers on aluminum heads, can anyone say stripped exhaust hole threads?
Anyway, thanks for the replies.
To starter change with headers
