Courtesy lights issue
Old Aug 1, 2017 | 09:35 PM
Kens94's Avatar
Kens94
Default Courtesy lights issue
Car is a 94 stock auto...Coming home last night I noticed the only interior lights working are the two hatch lights. None of the front lights are working. Tried the dimmer switch to see if I could turn them on manually but no dice. Anyone had this issue? If so what needs to be replaced. I assume it may be a fuse, relay, timer, ground? Thanks in advance!
Old Aug 2, 2017 | 04:12 AM
WVZR-1's Avatar
WVZR-1
First check I'd think the RH CTSY FUSE #36 likely in the IP box end of dash.
Old Aug 6, 2017 | 10:30 AM
Kens94's Avatar
Kens94
Big thanks it was that exact fuse. I feel so dumb, that is the first thing to check.
To Courtesy lights issue
