Broken transmission cooler line
Old Aug 6, 2017 | 07:27 PM
Jsonova99's Avatar
Jsonova99
Default Broken transmission cooler line
so in the midst of removing a leaking radiator on my 87 automatic I busted the bottom transmission line right at the fitting. I've thought about a quick fix with a cooler kit fitting and a flex hose but would rather just replace the line, I don't think it will cost much more. I've found kits that apparently fit from inline tube on eBay, assuming they do how hard are these lines to replace? Can you snake them from transmission to radiator just having the car jacked up?
Old Aug 6, 2017 | 08:17 PM
confab's Avatar
confab
Double flare it and put it back on?
Old Aug 6, 2017 | 10:24 PM
gerardvg's Avatar
gerardvg
Hi
You can easily bypass the radiator and put a transmission cooler in front of the a/c condenser, just run hoses from the existing lines to the air cooled trans cooler.
Old Aug 15, 2018 | 07:53 PM
KEVIN444's Avatar
KEVIN444
3rd Gear
I just need to know what the thread size is, i think I have to tap it out
Old Aug 15, 2018 | 08:33 PM
PatternDayTrader's Avatar
PatternDayTrader
The line was rusted to the fitting and you twisted into two didnt you ....
Old Jun 22, 2022 | 04:52 AM
i987c0sw0rth's Avatar
i987c0sw0rth
Does the transmission cooling system run at a low pressure?. Also, where are the connection points on the transmission housing, and can they be accessed with the car jacked up?. I am talking about a 1988 C4. I have thought about cutting out the leaking section and replacing it with braided hose and jubilee clips. Would that work?.
To Broken transmission cooler line
