85 Does not crank
Old Aug 7, 2017 | 05:37 PM
MustangGT99's Avatar
MustangGT99
1st Gear
Default 85 Does not crank
Back in May I replaced the starter in my 85 vette, manual trans. Worked good, about 2 weeks later I started having a random issue foot on clutch pedal, turn key, no cranking. SO I pooped started it once, no issue. One day getting ready yo leave my house, car started then stalled, after that would crank no fire. Had fuel pressure, but changed pump, strainer and filter. No go. Changed ignition module, then if you turned the ignition, starter would engage and would not stop turning until battery disconnected or dead. Changed ignition switch, now car will not crank again. Did check clutch safety switch and it is good. Anybody ever have an issue like this?
