Fixing 1996 Steering Column
I can pull the wheel off axis an inch but there is also a little play in all direction which I assume is a bearing problem as well as the pivot pins??
The steering also has a lot of play when steering left to right like an old lifted truck.
Does the lower "centering sphere?" wear out?
should I replace the upper AND lower bearing in the column?
