Help with headlight switch holder broken
Old Aug 16, 2017 | 03:56 PM
Rhensonsr's Avatar
Rhensonsr
Default Help with headlight switch holder broken
I pushed in my headlight switch and it moved into the dash. Evidently, a former owner super glued it in. Anyone have any suggestions or experience on how to fix this problem? Or, it is missing a piece?
Thanks!
Old Aug 16, 2017 | 06:55 PM
s carter's Avatar
s carter
Thanks!
That's Pretty Busted Up, without opening up a big can of worms to replace the Dash frame itself. I wonder if you pull it together the best you can then put a Layer or Two of Fiberglass Cloth and Re-drill the Hole or put a cut to size Steel plate and some how using the Bolt above.
Old Aug 16, 2017 | 09:17 PM
Rhensonsr's Avatar
Rhensonsr
I have some sheet metal that I am thinking about cutting to size, then using screws to attach to what is left of the plastic, and drill a hole as you suggested. Someone must have punched it. Thanks SC
To Help with headlight switch holder broken
