Need help - Interior lights issue
Old Oct 4, 2002 | 11:34 AM
Vic'89's Avatar
Vic'89
Default Need help - Interior lights issue
I am still having an issue with my interior lights staying on. This problem has been with me for 3 months now.
It looks like my "interior lights delay timer" is not working. The bad part is that this item is discontinued from GM. No dealers or vendors have one.
I have already replaced the rear hatch switch, that didn't help.
Everything is point to the "interior lights delay timer".
I want to bypass this somehow, anyone how to do this ?
Vic
Old Oct 4, 2002 | 12:00 PM
JonM's Avatar
JonM
Default Re: Need help - Interior lights issue (Vic'89)
I think if you just unplug it, it will keep the lights off all the time.
Old Oct 4, 2002 | 12:05 PM
Vic'89's Avatar
Vic'89
Default Re: Need help - Interior lights issue (JonM)
I have it unplugged for months now, the lights stay on. I have to pull the fuse in order for the lights to stay off.
Vic
Old Oct 4, 2002 | 12:37 PM
Fla96LT4's Avatar
Fla96LT4
Had to replace mine 3 months ago (due to dealer error) and it was an in stock order item at a local Tampa dealership (for an 87). The Last Detail may have some?
Old Oct 4, 2002 | 02:45 PM
JonM's Avatar
JonM
Here you go ...for the cost of shipping
http://www.corvetteactioncenter.com/...threadid=16917
Old Oct 4, 2002 | 06:12 PM
-=Jeff=-'s Avatar
-=Jeff=-
EDIT: the picture I originally posted was for the Starter relay.. PN 14093107
I have another one that is 14078902.
This is all I have, by looking at the diagram in my 89 manual it shows the timer tied to the harness and not mounted. If this is the case I no longer have the part you are looking for
[Modified by -=Jeff=-, 4:23 PM 10/4/2002]
Old Oct 4, 2002 | 06:21 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
Default Re: Need help - Interior lights issue (-=Jeff=-)
What is the part number on that thing?
Old Oct 4, 2002 | 06:23 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: Need help - Interior lights issue (Coupe89)
14093107
Old Oct 4, 2002 | 06:49 PM
Vic'89's Avatar
Vic'89
I'll post a pic later. But here is a description:
Mine is a yellow plastic looking piece about 2"x3".
It has a 5 ping connector going into it.
It has male ends on it, the wiring harness has female connectors.
2 of the wires are yellow.
Vic
To Need help - Interior lights issue
