Remove the cluster trim (8 screws), center console trim (5 screws- one is "hidden" and goes in from the cluster side near the top), fuse panel (3 screws)
Now remove the screws from the dash board. There are 5 on the front under the "lip" of the dash pad. 2 are on the cluster side, 2 are under the side above the console and one under the lip near the fuse box. There are two screws on either side of the defroster vents.
Now, grip firmly and pull, steady and straight back- NOT up! There are clips on the front of the dash near the windshield and one above the bread box.
