Timing chain RE & RE
Old Oct 4, 2002 | 04:07 PM
WEDGE's Avatar
WEDGE
Default Timing chain RE & RE
Just wondering how hard/long to do a timing chain in my garage with basic tools etc. My Chiltons says I will have to drop the pan but one of our tech says I should only have to loosen the front of it and push it down enough to get the chain cover off. I would like this job to be as quick and painless as possible.
Wedge. :rolleyes: :confused:
P.S. its an 84 vette.
[Modified by WEDGE, 8:11 PM 10/4/2002]
Old Oct 4, 2002 | 04:13 PM
AS84's Avatar
AS84
Default Re: Timing chain RE & RE (WEDGE)
I'd say 12-14 hours with appopriate tools and adequate beverage breaks :cheers: I just loosened the front of my pan and massaged the timing cover a bit and she slid rigt in place with no leaks. Preventative mainentance or broken parts??
Old Oct 4, 2002 | 04:25 PM
JonM's Avatar
JonM
It shouldn't take you long to do. And dropping the pan really isn't that hard either. I'll bet the gasket leaks a little anyway. You may also want to look into replacing the waterpump while you are at it. Just take your time and you will do ..OK....If you need any diagrams from the helms book, let me know.
Old Oct 4, 2002 | 04:56 PM
Barrier's Avatar
Barrier
Just curious, do the timing chains on L98 engines have a nylon gear on the cam? Does any body know the condition of these after say 100k, 125k, 150k miles? Years ago chains used to go on chevy engines at about 90k but that was with the nylon gear. The gears would actually disintegrate, with teeth falling off, causing the chain to jump. From what I have read on the Forum they now seem to last much longer and get replaced as a precaution rather than necessity. Is this true???
Barrier
Old Oct 4, 2002 | 05:21 PM
WEDGE's Avatar
WEDGE
Default Re: Timing chain RE & RE (JonM)
Yep I got another water pump to put on while I was in there along with a new chain cover since the original one now has a big slice:mad in it from my balancer(outer ring walked backwards off of the rubber sleeve:eek: )self destructing.
Wedge. :cheers:
Old Oct 4, 2002 | 09:07 PM
corvette1990's Avatar
corvette1990
Looking at my 90 chain and gears on garage floor, there is NO nylon gear, just metal. at 108k miles it doesn't look bad. It could be stretched a little, but not much. On my new rebuild project I am going with a cloyes 9-3145, and clean new GM timing cover, as the old one looks nasty. Because the water pumpclearance is so slim. I can not go with the nice edelbrok aluminum ones. Glad I replaced the Damper already. Seems alot of them are going these days.
Old Oct 7, 2002 | 03:26 AM
Ron78Z&66Vette's Avatar
Ron78Z&66Vette
I replaced my 85's a couple of years ago. About the only "special" tools I needed was a balancer puller, small gear puller, and a long #45 (I think) torx bit to get the lower torx screw for the A/C. I'd start on it first thing on a Saturday in case you run into any problems (tools or otherwise) you can wrap it up on Sunday if needed. I didn't pull my pan either, I just loosened a few pan bolts on each side. It took a little "persuading" to get the lower part of the timing chain cover with a new seal in though...but it WAS do-able.
Not sure when GM went to steel teeth on the cam gear, but my 85 had nylon, so it's a safe bet your 84 has nylon also. I changed mine at 150,000 miles. I had cracks on 6 of my teeth. The worst was almost cracked all the way through with less than 1/8" of material holding it on. The chain was also VERY sloppy.
My balancer slipped and I needed to replace it. I figured as long as I was down there with stuff torn apart, it might be a good idea to change the chain "just in case"....Im glad I did.
[Modified by Ron78Z&85Vette, 1:38 AM 10/7/2002]
Old Oct 7, 2002 | 02:18 PM
Barrier's Avatar
Barrier
Default Re: Timing chain RE & RE (Ron78Z&85Vette)
My car is a late '86. When did they switch to the steel gear??
'86 early or late?
Barrier
Old Oct 7, 2002 | 08:19 PM
Barrier's Avatar
Barrier
Default Re: Timing chain RE & RE (Barrier)
BTT
To Timing chain RE & RE
