Loose tilt steering column
Old Oct 4, 2002 | 07:41 PM
Midwest Vette's Avatar
Midwest Vette
Default Loose tilt steering column
My tilt steering column is loose. I tightened the 3 torx headed bolts under the turn signal switch. I'm not sure these are the right bolts to tighten. Without the wheel on the column it is hard to tell. I would hate to get it back together and it not be fixed. Any help would be greatly appreciated.
Ron :cheers:
Old Oct 4, 2002 | 08:14 PM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Default Re: Loose tilt steering column (Ron 93 Vette)
I'm not sure, either, but as long as you're in there, back the screws out and slather some thread locker onto the bolts.
Also, the 1/8" diameter pin holes, the holes can oval-out in that pot metal core, and the column will loosen up again no matter what. But they only oval out if the column has been flopping for a long time.
Someone on the forum here has a web page up with a steering column disassembly and repair laid out. Check the archives in C4 tech and C4 general.
Old Oct 4, 2002 | 08:20 PM
Sharky Guam's Avatar
Sharky Guam
Default Re: Loose tilt steering column (Matt Black)
I once had a similar problem with the ovaled holes. I used a small amount of JB Quick Weld on the slots. It took up the damaged area that was worn out. Just use the stuff sparingly. After tightening the screws, make sure to clean up any excess and let it cure for about fifteen minutes before reinstalling the rest of the column parts. The fix has held for over a year now with no signs of failure.
:cheers:
Old Oct 4, 2002 | 11:18 PM
Monkey Business's Avatar
Monkey Business
Default Re: Loose tilt steering column (Sharky Guam)
I had a loose steering column and found that it had to be rebuilt. A couple of bearings down in the column went bad. Tightening the bolts didn't work. Had to spend 75.00 for the original manual but was well worth it.
Old Oct 4, 2002 | 11:52 PM
2012 coupe's Avatar
2012 coupe
Chevey makes a repair kit for the problem of the holes in the plastic being out of round. The kit has larger pins and springs for the reapir.
I do not remember the kit #, but there are two of them. Try Chevey under steering wheel coupler kits, or something like that?
:flag
Old Oct 5, 2002 | 04:13 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
There are four hex head bolts that hold the tilt mechanism. The two pins that the tilt section pivots on are pressed in. You can pull those out with some 8-32 steel screws, nuts, and washers (might be metric but they are so small either will work) and a socket to pull the pin into. Once those are out, you can get the 4 bolts that are loose and also check the wear in the holes they go into. Use blue loctite to prevent this problem from happening again.
Old Oct 5, 2002 | 05:45 AM
388 SOLid RoLLeR's Avatar
388 SOLid RoLLeR
Default Re: Loose tilt steering column (AquaMetallic94LT1)
I still have the problem and purchased a barely used colum to solve it. I found out the real reason. The tilt spring has too much tension. GM had a stronger spring put in because the newer airbag wheel was heavier. Voila our knuckles get worn cuz of the pressure. I ve seen a few columns with the problems and the knuckles were out of whack. Tightening my torxx bolts helped a little. What helped the most was the pins that go in the sides. After removing them i took a flathead and a hammer and tapped ridges in them. I had to hammer them back in the column for a tight fit. helped about 90%. ... but it still movess....... thank god for the camber brace.... stops 100% wheel squiggle.
Old Oct 5, 2002 | 11:55 AM
Midwest Vette
Thank you all very much. It looks like I have more work to do. :cheers:
Old Oct 5, 2002 | 12:29 PM
kabnvtt's Avatar
kabnvtt
Hey Ron 93, I am doing the same thing to my 87 right now, I also had to take out the ignition switch to get deeper inside the column. Still have not got to the four screws metioned. If you have any tips please let me know.
Old Oct 6, 2002 | 03:45 AM
Ron78Z&66Vette's Avatar
Ron78Z&66Vette
If you don't already ahve them here's some useful links:
http://www.aros.net/~rbuck/column/tiltcol.html
http://www.gnttype.org/techarea/susp..._steering.html
Old Oct 6, 2002 | 01:34 PM
Midwest Vette
Thanks Ron,
Those are great sites. :cheers:
Old Oct 10, 2002 | 05:08 PM
Midwest Vette
I pulled the column from the car, the tilt bolts that loosen up were tight. There is a lot of slop in the pivot pins. it is wallered out from the heavy tilt spring. It looks like a rebuild is in the works. :smash:
Old Oct 10, 2002 | 05:21 PM
388 SOLid RoLLeR
funny how most 93s and earlier have this problem. Mostly 93s. :bs
Old Oct 10, 2002 | 06:04 PM
Moonpie87's Avatar
Moonpie87
Default Re: Loose tilt steering column (388 SOLid RoLLeR)
Sorry to steal your thread, But what would you do if your tilt spring is broken??? My tilt just falls in my lap, and does'nt spring back up. How much deeper do you go into the column?? and where do you get this overhaul manual for this critter.??
Old Oct 10, 2002 | 09:18 PM
Midwest Vette
A tilt spring would be an easy fix. I am using a G.M. service manual. You can get them at helm publishing.
Does anybody know if they lightened the tilt spring after 93 ?? Maybe I should go with a pre 90 spring since they are lighter. :smash:
To Loose tilt steering column
