Trans slip
Old Aug 27, 2017 | 09:13 PM
84grb's Avatar
84grb
Cruising
Default Trans slip
Hey..Problem just started..I have a 84 c4 AUTO TRANS with 70,000 miles..While driving yesterday I came to a stop light..When i pulled away tranny started to.slip. I then barely made it home only 2 miles away..Slipping in all gears including reverse..Couldnt break 15 mph..Checked fluid level and no burnt smell with proper color. ..Got up next day and car was fine for about 30 min then same problem. .I then changed fluid and filter and car was fine all night. (About 3 hours of driving) Then today (Sunday) problem returned and barely made it home..Any ideas would help..
THANX
Old Aug 27, 2017 | 10:04 PM
arbee's Avatar
arbee
THANX
You need to put a pressure gauge on when it is doing this and note pressures in all gears.
Old Aug 27, 2017 | 10:40 PM
84grb's Avatar
84grb
Cruising
At this point i dont have pressure gauges..Will have to pick one up.
But do u have some idea what could b causing this? Im good with motors n manual trans..Just dont know much about auto trans repair
Old Aug 28, 2017 | 01:02 AM
confab's Avatar
confab
Check your TV cable for damage and setting. Should be full tight at WOT.
Old Aug 28, 2017 | 07:33 AM
84grb's Avatar
84grb
Cruising
Already checked tv cable..seems ok
Old Aug 28, 2017 | 06:45 PM
84grb's Avatar
84grb
Cruising
Im sitting in car..in park..i can here a low pitched wine also in neutral..i have no 1st or 2nd gear..if i rev i can just barely get reverse or drive..plesse help
Old Aug 28, 2017 | 09:07 PM
arbee's Avatar
arbee
We can't wave a wand and cure your problem. I suggested you get the pressures checked. Until you do, anything would be a guess. With the wining you describe, it may be your pump is pooched.
Old Aug 29, 2017 | 11:13 AM
84grb's Avatar
84grb
Cruising
Ok..thanx
Old Aug 29, 2017 | 01:22 PM
confab's Avatar
confab
That's all you need to know. IF the TV is fine and the fluid level is fine and you didn't shake the filter off.. It's internal and it needs to be rebuilt.
Sorry, bro.
Old Aug 29, 2017 | 03:37 PM
84grb's Avatar
84grb
Cruising
A bad or unadjusted TV cable could cause the trans to slip?
thanx
Old Aug 29, 2017 | 06:04 PM
confab's Avatar
confab
thanx
Absolutely. A misadjusted TV can burn one up.
Depending on who built the trans, a broken cable can also. (There's a ball builders leave out that causes a problem there.)
Old Aug 29, 2017 | 06:22 PM
arbee's Avatar
arbee
In post #6, the OP describes reving the snot out of it to BARELY get reverse. I would venture a guess he is beyond a maladjusted TV cable.
Old Aug 29, 2017 | 07:39 PM
confab's Avatar
confab
Yeah..
To Trans slip
