how do you remove the battery?
Old Oct 4, 2002 | 09:05 PM
purplevetteowner's Avatar
purplevetteowner
4th Gear
Default how do you remove the battery?
My 95 vette won't start and the popular theory is either a bad battery or a bad ground. Sounds easy enough just take out the battery have it checked and look for loose ground wires. WRONG! I can't figuer out how to get the battery out!
Any Ideas?
Old Oct 4, 2002 | 09:08 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: how do you remove the battery? (purplevetteowner)
remove the three screws from the wheel well,remove the screw on top of the gill panel.
If you look between the crack where the gill meets the rocker panel, you can see a bolt there. Just loosen it, do not remove it.
Now you can remove the gill panel and get to the battery.
Don't have any pics to show, but it's a fairly easy job.
Old Oct 4, 2002 | 09:17 PM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
Default Re: how do you remove the battery? (Mr Mojo)
Yep what mojo said. Oh yeah welcome aboard the forum. You will soon be addicted. :seeya
[Modified by joecaver, 8:19 PM 10/4/2002]
Old Oct 4, 2002 | 09:27 PM
WhiteIce-ChicagoRoss's Avatar
Default Re: how do you remove the battery? (joecaver)
Yea its fairly easy you just have to have a Torx bit socket set.
Old Oct 4, 2002 | 09:39 PM
NoWorries's Avatar
NoWorries
To elaborate on what Mr. Mojo said, the two bolts are 10mm.
Old Oct 5, 2002 | 06:35 PM
tuband's Avatar
tuband
Cruise-In I Veteran
Been there, done that! and also what Mr. Mojo & the others said.
Two years ago on Halloween night my battery died completely as I was driving home from work. I had just read on the Forum the procedure for changing the battery ... wow, what timing.
Anyway, I changed the battery out in a short amount of time (I had coasted into someone's front yard) with my wife holding a flashlight & tools and with all the "lil grabber" trick or treaters going by. Interesting memory, to say the least.
Welcome to the Forum ... not only is it addictive but you will find an entire host of "experts" here who can help you out in ways you never thought of.
tuband
Old Oct 5, 2002 | 06:58 PM
88-L98-Z52's Avatar
88-L98-Z52
Uh... don't believe any of the replies... you can't change a battery in a Corvette.. you have to throw the car away and buy another one!!!
(just kidding!!...) But.. I remember seeing (I think on the Corvette Fever website) a step by step procedure with photos that shows the procedure. It was one of the first repairs I ever had to make on my car too, and I was astonished to learn body panel removal was required. I still wonder why they didn't put it behind the driver's seat like they did on C3s.
Old Oct 5, 2002 | 07:45 PM
Zora's Avatar
Zora
Cruise-In I Veteran
Cruise-In II Veteran
Old Oct 5, 2002 | 08:38 PM
don hall's Avatar
don hall
Try these links and invest in some manuals: http://www.factoryautomanuals.com/ http://listings.ebaymotors.com/aw/pl...760/index.html
Old Oct 5, 2002 | 09:50 PM
vert2go89's Avatar
vert2go89
Cruise-In I Veteran
Default Re: how do you remove the battery? (tuband)
sheesh I thought experts got paid for their wisdom so I must be an ameteur.
Old Oct 6, 2002 | 01:42 AM
88-L98-Z52's Avatar
88-L98-Z52
Default Re: how do you remove the battery? (vert2go89)
Hey... experts and professionals in all walks of life and professions will often donate their time, knowledge and resources for the benefit of the less fortunate... It's sometimes referred to or considered to be... charity... humanity... caring... sympathy... empathy... kindness... sharing and generosity....
I don't know what an 'ameteur' is, but it must be someone without those characteristics or qualities... However, an 'amateur' is one who engages in a pursuit, study, science or sport as a pastime rather than as a profession or one who lacks experience and competence. But sometimes even amateurs will volunteer time, resources, or even their limited knowledge to either aid another or to add to their own knowledge and/or gain experience.
Old Oct 6, 2002 | 09:27 PM
purplevetteowner
4th Gear
Hey you guys are great!! Thanks for all the help, it worked just like you al said. Now that I know where to get good answers from I'll start another thread with some little nagging problems I've been having.
To how do you remove the battery?
