this is one area where VT3 and I disagree - personally, i'd replace the factory studs with 1/4" longer moroso studs (p/n 97020), and use fel-pro 1628 (blue) silicone rubber gaskets. clean both surface "squeaky" clean, and install dry without any kind of additional sealant, AND TORQUE TO SPEC.
your VC's don't look all that bad - i'd give them a good cleaning and a fresh topcoat with satin nickel valve cover paint.
I noticed that these are 1/4-20 x 1 3/4 studs according to the Moroso part number above. Is this correct? I was going to order when I redo my valve covers but was concerned since everything else seems to be metric.
1/4-20 is correct. on the 85, and i'm guessing all L98's, everything within the basic engine is UNC = Unified National Coarse threads, whereas attachment parts and accessories are metric - plenum, runners, throttle body, etc.. a mixture of apples and oranges. enough to drive a normal person NUTS!!!
id refurb your 85 vc's using either joec's method or mine (both work and produce long lasting beautiful vc's) and personally on the 85, and early 86, i would not use anything other than cork with a correctly applied hylomar coating. the surfaces are different than the aluminum headed late 86-onward. you will likely find a hideous application of rtv under you vc's and you will spend more time trying to remove it than getting the vc's off.
hylomar + cork on iron heads is my recommendation for iron heads. notethat hylomar needs to be "printed" then seperated and left to sit for 5-10 minutes before mating surfaces.
good luck and let us know how whivh dirxn you go and how it works out.
VT
What hylomar should I buy? What do you mean by printed and then separated? I apply the hylomar to the iron heads and valve covers let sit for 10 minuets and then mate them together with the gasket in between?
