I have a base model 1996 Corvette automatic. I need to have the CCM rebuilt. Sent to Davies Corvettes in Florida. Responded it's not rebuildable.
They have been unable to find 1 that is rebuildable. ANY HELP WOULD BE GREATLY APPRECIATED.
I believe that the later C4 CCM/BCM are rebuild-able through a GM program. If it's NOT then I believe it's returned with no charges. I've no idea who does Davies and maybe they actually just pass it on through a dealer so ...............
What issues did you have?
A used if supplied with the known KEY RESISTANCE would likely MAKE RUN but then you'd have incorrect VIN and ODOMETER information. How much will Davies charge to remove VIN & correct the odometer on a known good unit?
