Water Pump Info
Old Oct 5, 2002 | 11:43 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Water Pump Info
Was going to change my Lwr. Radiator hose....what a surprise...the fitting on the water pump to install the radiator hose on is all white...eaten up with corrosion....should I replace the water pump...although its been working fine...or what...never seen this much aluminum corrosion before...
How hard...and what do you have to do a water pump change???? This is an 1984 vette.....
can you guys help????
thanks
tony :confused: :confused:
[Modified by oldace84, 10:44 PM 10/5/2002]
Old Oct 6, 2002 | 01:25 AM
JonM's Avatar
JonM
Default Re: Water Pump Info (oldace84)
This is not written for an 84 ...but it is very close.
https://www.corvetteforum.com/techti...D=54&TopicID=2
Old Oct 6, 2002 | 01:43 AM
oldace84's Avatar
oldace84
JonM,
Thanks again for the help......but the manual for 1984 gives a buch of things to do.....???????
Must be an easier way....I'm not lazy...but.....I keep working on this vette...had since 1989....now getting into at my old age.......everytime I get one thing fixed....$$$$$$$$spent I find something else to do.....oh well I guess it is fun...
Hey JonM...THANKS FOR THE info on replacing my side moldings....only thing to finish is the moldings behind the rear wheels.....
tony :cool:
Old Oct 6, 2002 | 01:46 AM
oldace84's Avatar
oldace84
I'm ordering a flowkooler water pump and thermostat..160...using a Mr. Gasket now......but they say robertshaw is better.....
It's only money....
tony :smash:
Old Oct 6, 2002 | 03:15 AM
vettl83's Avatar
vettl83
It's only money....
tony :smash:
And time, they are an expensive and addicting hobby. 84 CF 91 ZR-1
To Water Pump Info
