NEW (and first) E.T. s
Old Oct 5, 2002 | 11:27 PM
keekster's Avatar
keekster
Default NEW (and first) E.T. s
This is on my stock 92 6 Speed.
REACTION .676
60 FOOT 2.550
300 fT 6.404
1/8TH 9.452
1/8 mph 80.52
1/4 14.2
1/4 mph 103.00
I left traction control on that bogged the motor of the line hard. OOPS. What do you all think I could run If I learned to drive ?
Also car was at 225 Degrees when run.
[Modified by keekster, 3:28 AM 10/6/2002]
[Modified by keekster, 4:25 AM 10/6/2002]
Old Oct 5, 2002 | 11:45 PM
Drewdog's Avatar
Drewdog
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: NEW (and first) E.T. s (keekster)
If you had trouble hooking up you could try lowering the PSI on your tires. I ran a 14 flat with just muffler elims and a 2.30 60 foot.. last time I went I have Corsas and got a 2.00 60 foot and I ran a 13.4@102. I would imagine you would run somewhere in the mid 13s :yesnod:
Old Oct 6, 2002 | 12:31 AM
keekster's Avatar
keekster
Default Re: NEW (Drewdog)
Hi Drewdog
Actually I had the reverse of not enough traction I had to much (traction control) :)
Old Oct 6, 2002 | 01:29 AM
Drewdog's Avatar
Drewdog
Default Re: NEW (keekster)
you only got to get in one run?
Old Oct 6, 2002 | 01:32 AM
vader86's Avatar
vader86
You really need to work on launching, but if you had the ASR on, that wouldve been a major factor in that 2.55.
Mph is good though, you can drop that time SEVERAL tenths.
As suggested, drop the psi in the tires a little to help with launches.
Old Oct 6, 2002 | 02:31 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
With a 103mph trap speed you have mid 13's, and a lot of it will happen when you drop that short time into the 1.9s or 1.8s. Optomizing your shift points and technique will also help.
Are you hooked on it yet?? Have fun.
Old Oct 6, 2002 | 02:43 AM
Black88Vette's Avatar
Black88Vette
Not bad at all. Especially if that is the first time that you have run! :cheers:
Old Oct 6, 2002 | 03:25 AM
keekster's Avatar
keekster
Default Re: NEW (65Z01)
Definelty hooked :)
Unfortunatley I got there late and only had a little time :(
[Modified by keekster, 7:26 AM 10/6/2002]
To NEW (and first) E.T. s
