1985 TPI Failed
Old Oct 24, 2017 | 09:11 PM
856SPEED's Avatar
856SPEED
Originally Posted by renaissance_wk
Thanks, I purchased the Multiport Pre-Wired Retro-Fit EZ-EFI® Kit #302000 direct for $718 including freight. Looking forward to getting it and installing it!
Nice! Let us know how it works out for you. I never looked back.
Old Oct 25, 2017 | 09:45 AM
pacoW's Avatar
pacoW
trying to figure out ignition issues now on the '96 I got, would give anything to go back to carb and HEI distributor.....I know how to fix those.......cheap.
Old Oct 28, 2017 | 09:42 PM
81c3's Avatar
81c3
That is one of the oddities with my car. It doesn't throw codes!? Also I can start it and it runs like cr@p, and then I can leave it sit for a half hour and it will run fine. It's so random!
Sounds fuel pressure related... is the FPR in good working order? Fuel filter? Fuel pump? Fuel pressure itself up to specs? Original injectors?
