Differential "chattering" noise.
Old Sep 19, 2017 | 11:09 AM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Default Differential "chattering" noise.
I just replaced the differential oil in my 85 4+3 with 80W90 GL5 (1.4 quarts) and 4 oz. of AC Delco additive for the limited slip differential. I did this because the differential was getting a light chattering noise at very low speed from a stop, and going around a tight bend slowly. Right after the change I noticed that the light chattering is still there but goes away after about 15mph as before. Does it take awhile for the AC Delco LSD additive to quiet this down, or do you think I shouild add another 4oz. of additive? Everything in the driveline seems to be fine.
Old Sep 19, 2017 | 11:21 AM
WVZR-1's Avatar
WVZR-1
You could certainly have issues with the differential that's maybe NOT clutch related OR depending upon miles maybe the D44 is just plain "wore-out" and needs a tune-up. Clutch pack & pinion washers only maybe or pinions, pin and washers. Maybe the case is worn for the pin. Lots to check.
Old Sep 19, 2017 | 12:31 PM
FOURSPEEDVETTE
A little side note. The car currently only has 51,000 miles and always been well taken care of and maintained. Never beat in other words. At highway speeds there is absolutely no whine or strange noises. The chattering does not always occur. It only seems to be sporadic at very low speed.
Old Sep 19, 2017 | 05:13 PM
FOURSPEEDVETTE
It's more of a metalic clicking noise at low speed. The gear oil that was removed was fairly clean. No metal fragments in it.
Old Sep 20, 2017 | 07:45 AM
Cjunkie's Avatar
Cjunkie
Check the half shaft U-joints.
Old Sep 20, 2017 | 09:09 AM
WVZR-1's Avatar
WVZR-1
Originally Posted by ihatebarkingdogs
I had an 88 years ago that I put GL5 lube in the rear diff. It squealed during turns at low speeds. I added the GM additive, and it made no difference. Still squealed. I sucked the GL5 lube out with a suction pump and refilled with GM's diff oil, and another 4oz of the additive. Noise was gone.
I don't remember the source, but I recall reading that GL5 is not compatible with preloaded friction posi differentials like the Dana's use. It has to be GL3 or GL4, with the additive.
I believe that the C4 specification for rear-axle was always GL5. GM 1052271 which was application specific from GM - BUT since it was actually also specified for earlier '55+ GM "Limited Slip" the label on the back-side maybe had "EXCEEDS GL4 specifications". I have original GM# 1052271. The label also mentions that NOT ALL GL4 LABELED PRODUCTS WILL PROVIDE SATISFACTORY SERVICE. I don't recall the label ever mentioning an actual API.
A quick check of Dana usage in FOMOCO and MOPAR the specification is always GL5 with a note to add "modifier". The "paper guide" I use is from Castrol and 10 years old but I relied on it heavily and not the web-based guides.
GL4 and GL5 gets debated more frequently when discussing older manual transmission because of syncronizer ring materials.
Old Sep 20, 2017 | 09:35 AM
Cjunkie's Avatar
Cjunkie
GL4 in older manual transmissions, GL5 in the differential.
Old Sep 20, 2017 | 04:02 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Don't be afraid to double up on the LSD fluid additive.
Some of the dino oils need an extra shot to loosen the oil.
Also run the car in a slow tight circle for a few revolutions in both directions to get lube between the plates.
Old Sep 25, 2017 | 06:41 PM
FOURSPEEDVETTE
Well...... So far I wasted $500.00 trying to eliminate this "metalic" popping or snapping noise in my left rear wheel area at very slow speed! I replaced the 80W90GL5 gear oil and 4oz. Delco additive first in the differential. No improvement. Today I had a mechanic tell me he fixed it. He replaced the inner and outer half shaft U-joints. The noise is still there! He didn't fix it! He said he couldn't find anything wrong with the wheel assembly. There is no wobbling, vibrating, or humming noise in the rear end. I had this same snapping/popping noise in a previous car I had and it only needed LSD additive put in. Noise disappeared right away. Should I drain 4oz. of gear oil out and add 4 more oz. of AC Delco LSD additive? This is getting expensive!
Old Sep 25, 2017 | 08:12 PM
WVZR-1's Avatar
WVZR-1
You might want to do some checks - perhaps starting with the procedure Will/"rklessdriver" mentions for checking "break-away" with the rear still in the car.
https://www.corvetteforum.com/forums...post1591070166
I'd think you could check excessive pinion/side gear in the carrier by quick twists of the wheel forward backward with the pinion locked in place. You could certainly see if you can easily recreate what you say you hear.
Old Sep 25, 2017 | 08:43 PM
xrav22's Avatar
xrav22
I used 2 bottles(no probs) when I changed oil in the D36. But I also changed wheel bearings and ujoints also. put the car up and check 3-9,12-6 and calipers,pads(bend the springs out more), bushings ect. My long looked for clunk(6months) turned out to be loose shock mount(lower). Before that I had 2 rear shocks worn out and making klunking. I only found out by driving thru the alley without the rear shocks. Good luck investigating
Old Sep 25, 2017 | 09:38 PM
WVZR-1's Avatar
WVZR-1
Originally Posted by xrav22
I used 2 bottles when I changed oil in the D36. But I also changed wheel bearings and ujoints also. put the car up and check 3-9,12-6 and calipers,pads(bend the springs out more), bushings ect. My long looked for clunk(6months) turned out to be loose shock mount(lower). Before that I had 2 rear shocks worn out and making klunking. I only found out by driving thru the alley without the rear shocks. Good luck investigating
The more narrow the alley and the taller the buildings seems to be a + for sure. You'd be surprised what you hear in the alley - exhaust matters!!!!
Old Sep 25, 2017 | 10:54 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
I can't speak to the diff oil you use ... but don't think that it hurts anything at all to run two bottles of the additive. I always have to mine and I was putting 15K a year on the car for 6 years as my year round dd.
Full disclosure when I bought the car with 30K I changed the diff as well as oil & trans over to amsoil. but when I took the long slow sharp right turn into our driveway the right rear tire seemed to be chirping (don't know if that's the same as a chatter) . Pull a little bit out added a 2nd bottle and the chatter went away. Have run it this way over the past 100k I've put on the car and changed the diff fluid after about 70K and did it again with 2 and I've never had a problem. probably overkill.
Old Sep 26, 2017 | 11:20 AM
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
Usually posi problems from incorrect lube results in jerking at low speeds during cornering, but usually doesn't produce any noise. A "clicking" from the rear, especially on take-off in a straight line can be the rear axle splines within the rear hub. Even with the nut tight. There is a GM derelin washer available to cure this noise. I'm sure there are threads on here that mention this washer and noise. First I'd get rid of the GL5, and then evaluate any noise or clicks.
Happy hunting.
Old Sep 30, 2017 | 10:50 PM
FOURSPEEDVETTE
I added a second bottle of AC Delco LSD additive to the differential and the clicking noise is gone! I also contacted the mechanic's shop owner about them charging me all that money, (almost $500.00) for nothing! I got most of my money back! I only paid $65.00 for the "U" joints. Even though there was nothing wrong with the old ones, I have new ones with grease fittings in them now.
Old Sep 30, 2017 | 11:00 PM
xrav22's Avatar
xrav22
To Differential "chattering" noise.
