C4 air conditioning
Old Sep 20, 2017 | 02:31 AM
Richard Benzer's Avatar
Richard Benzer
4th Gear
Default C4 air conditioning
Hello fellow corvette lovers,
I have a 1992 c4 where the a/c will quit blowing cold and tha a/c light blinks on and off. If I disconnect the battery, totally killing power to the car, then reconnect it. The a/c will work fine for awhile
Could be minutes, hours , or days. Then it does it again. I then have to disconnect the battery agian....
Does anybody have any ideas what this could be? Any help is greatly appreciated
Old Sep 20, 2017 | 11:51 AM
Keith Huffstutler's Avatar
Keith Huffstutler
Is this the C60 (manual) or C68 (automatic) controls? Since it blinks, I am assuming that it is the C68. What it sounds like, is that the head unit needs servicing (like a capacitor failing). See here: http://www.batee.com/corvette/dcrg/9096_hvac/
Keith
Old Sep 20, 2017 | 11:48 PM
sprink94's Avatar
sprink94
To save you some time when resetting...try disconnecting the A/C controller 5 Amp fuse in the fuse box. That is how I reset mine after changing the pressure switch and recharging.
Old Sep 21, 2017 | 03:48 AM
Richard Benzer
4th Gear
Thank you everyone . I will order the repair kit Keith sent me a link to at batee.com . I do appreciate it...
Old Sep 21, 2017 | 04:01 AM
Richard Benzer
4th Gear
Sounds the same as my problem a guy named Keith on forum gave me a link to batee.com for a repair kit for the a.c. programmer for the c68 digital climate control. I am going to buy that and fix it myself. I hope this helps..
Richard
Old Sep 21, 2017 | 04:03 AM
Richard Benzer
4th Gear
Keith
Thanks Keith I will order the part tomorrow and try to fix it myself. I do appreciate it. Richard
To C4 air conditioning
