IP problem Top Half dim, bottom half Good
Old Sep 22, 2017 | 08:29 PM
split-end's Avatar
split-end
Default IP problem Top Half dim, bottom half Good
Has anyone had this problem where the Instrument Panel (IP) is working properly, but half of the IP (MPH, fuel gauge) is not as clear/dark as the bottom half (odometer)? If so, how did you fix the problem?
Old Sep 23, 2017 | 02:22 AM
Cliff Harris's Avatar
Cliff Harris
Replace or upgrade the backlight bulbs. I put LEDs in mine, which is a great improvement.
Old Sep 23, 2017 | 12:36 PM
split-end's Avatar
split-end
Default Back light Bulbs
Hi Cliff,
If it is possible, please give me the information/instructions on how to replace the back light bulbs and where to get the bulbs.
Thanks,
Gordon
Old Sep 23, 2017 | 02:47 PM
split-end's Avatar
split-end
Hi Cliff,
I found out how to remove the IP, but do you know the # of the bulb you replaced in the IP and where did you buy it from and how much was it.
Old Sep 23, 2017 | 06:01 PM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Are your LEDs dimmable, or only on at full intensity? What color did you use?
Thanks!
To IP problem Top Half dim, bottom half Good
