91 Fuel Computer Accuracy
Old Sep 24, 2017 | 12:36 AM
polo91's Avatar
polo91
Default 91 Fuel Computer Accuracy
My six speed roadster never quite got the mileage that I thought it should. After owning the car for ten years I final checked it out by measuring the actual quantity and the actual distance. First of all my speedometer and odometer are dead accurate. So it turns out that the onboard fuel computer is about two mpg low. Last month on a 1600 mile trip to see the eclipse the computer showed 24.2, actual manually measured was 26.6. Since then I have checked weekly my daily driving which is 25/75 city/highway. Generally shows about 18.5 and actual is about 20.5. By the way the trip was mostly above 70 mph with A/C. Over all my old high mileage C4 is still one of the best looking Corvettes and a pleasure to drive.
Old Sep 24, 2017 | 08:42 PM
Kevova's Avatar
Kevova
It's a calculation based on expected fuel use under the engine operating conditions. There are a lot of variables. I have never seen one that was 100%, they can be close. Myself I worry more about the range feature...normally when I'm in the middle of nowhere.
Old Sep 24, 2017 | 09:20 PM
ddahlgren's Avatar
ddahlgren
It uses injector flow as an input so the injectors have to flow correctly or the value changed. The fuel pressure is obviously part of the flow rate.
Old Sep 26, 2017 | 09:14 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I agree with ddahlgren that I have heard it is based on injector pulses to calculate the amount of fuel used. There are some things that can alter the actual from the expected flow.
I have also heard that it can be adjusted in the tuning.
On my C4's most have been pretty good. My '85, '87, '88, '94 and '95 were very close although my '96 reads about 2mpg lower than actual.
Both of my '99's read about 2mpg higher than actual and on the C5 section this seems to be pretty common.
Old Sep 26, 2017 | 11:59 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
X3 on the injector flow x injector on-time. vs. vehicle distance travelled. Pretty simple calc...easily messed up by fuel pressure, partially plugged injectors, worn injectors, etc.
To 91 Fuel Computer Accuracy
