I got the "ABS active light"...
Old Oct 7, 2002 | 03:33 AM
devilfish's Avatar
devilfish
Default I get the "ABS active light"...
...When I run over bumps in the road? Whats up?! Bad censors?
[Modified by devilfish, 8:44 AM 10/7/2002]
Old Oct 7, 2002 | 07:59 AM
Ramjet's Avatar
Ramjet
Default Re: I get the "ABS active light"... (devilfish)
When my 92 did that, I was a little low on brake fluid. Topped it off and that took care of it.. :)
Old Oct 7, 2002 | 09:07 AM
devilfish's Avatar
devilfish
Default Re: I get the "ABS active light"... (Ramjet5)
thanks, will try that..
Old Oct 7, 2002 | 12:06 PM
fullboogie
Mine does the same thing when I hit bad bumps. Don't worry about it.
Old Oct 7, 2002 | 12:53 PM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Do you feel the accelerator pedal push back on your foot when the light goes on? If it is the only light that goes on (ie., the BRAKE and Service ASR lights don't go on), then it sounds like a normal condition. The sensors have detected wheel slippage and the ECM has begun taking steps to arrest it. The first step is timing retard to reduce power (don't really feel that), then the accelerator is pushed back, that one you feel.
Old Oct 8, 2002 | 02:13 AM
R23HTC's Avatar
R23HTC
Default Re: I get the "ABS active light"... (92Shawnster)
This is what happens if he has the A ASR active light come on. He stated his ABS active light comes on.
When my shocks were bad, I noticed the lights (either of them) would be more active than normal. Just something else to check into. :yesnod:
Old Oct 8, 2002 | 11:36 AM
ShawnZR-1's Avatar
ShawnZR-1
Default Re: I get the "ABS active light"... (R94 LT 1)
:bb Oops, I totally mis-read that one! Ok then, if you are getting the ABS light with no other, (and not braking at the time), either a sensor is on its way out or possibly an intermitent connection.
To I got the "ABS active light"...
