Ride Control
It sounds like your car my have been lowered by a previous owner. I rarely scrape anything in my 92 convertible.
Raising the car.....the back is easy, but the front is another story. The shocks have nothing to do with ride height.
If you just want a more comfortable/softer ride, replacing your FX-3 Bilstien's with something like a KYB will do the trick.
new car to me I have a lot to learn. Cooling fan is not coming on with A/C and is getting hot at red lights. Probably a relay somewhere. I guess I'll order the manual so I'll at
least have a clue where to look for this stuff. Too bad it doesn't come with the car. LOL. The car only has 21,454 miles on it. Also, having trouble with the covertible top cover
getting it to properly unlatch. Works only sometimes. Any help is always appreciated.
Tire size for '92 was 275-40-17, but that is irrelevant to your issue.
For the a manual, get the red Factory service manuals, not Chiltons ior something else. You should be able to find the 2-volume set on ebay.
For the top, is it the pins on the back deck that are being difficult? If so, you can adjust (by trial and errror) the release cables once the deck lid is up.
Also, when car first begins to turn over there is a loud rattling valve noise from under the hood. Car doesnt seem to have enough miles on it for bad valves I would think. Thoughts.
Problem might be the solenoids that release the deck.
There are manual release levers tucked away, (and hard to see), in the area where the top seat-belt mounts are.
It can be pricey to replace/rebuild the system depending on the problem. Bilstein used to offer a shock rebuilding service for the FX3 system, but IIRC, parts for the rear shocks are no longer available.
Going with a standard-type shock will be the best way to improve the ride. Bilstein Sport shocks will work as will the KYB Gas-A-Just shock. These shocks can be found online at places like RockAuto, Amazon, Vette Brakes, Van Steel, or some of the CF Supporting vendors.
Coilovers are another alternative and they can adjust the ride height. But the front and rear leaf springs will have to be removed. The rear spring is pretty simple to do, but the front spring does take some effort. You will need to get the car a good 3' off the ground to do this.
It sounds like a previous owner may have installed a lowering kit. These kits typically have a set of blocks that install at the front spring and longer bolts for the outside ends of the rear spring.
Went with Nitto NT555 G2 for tires and they are great.
The low mileage cars just need a lot of attention since they did not get driven much. Keeps the interior and exterior in great shape but does not help in the mechanical end of things. They need to be driven.
You will find that most replacement parts for just about any American car will show as being made in China, especially electrical parts. Sometimes you will luck out and find a part that is made in Mexico, Japan, or some other country. The manufacturers look for a place to get parts made at the lowest cost and still meet the specifications and (hopefully) some level of product life expectancy. Unfortunately, that is something that is rarely seen anymore.
Even brand new cars have some percentage of parts made off-shore. It's all about saving money.
Mine was also a low mileage car and I make sure I drive it enough to go through at least a tank of gas a month to keep it running as it should.
Also if you update your profile to include your location a nearby member might offer to help. Also have you checked with the local Covette Clubs to see if anyone might be able to offer some advice?
both of them and now it is working perfectly. Isn't always what someone else has already done that gets to you. Oh Well. KYB shocks are one the way for my weekend project. Ordered manuals from ebay, Also ordered a double din Sony Car Stereo. Will be nice to finally clean up the sound. Local shop wants over $500 to just install. For that kind of money I think I'll take a stab at it first, then if I run into problems I'll let him finish it. Bought a kit from Corvette Central to get the engine cooled down. Wasn't very much. I may let my mechanic put it in as you have to remove a few things to get access to the factory head plug. Looks kind of tough to get to. I am having the biggest problem picking out speakers. There are so many to choose from out there. I really don't want to hack away at the enclosure or use MDF to make an adapter. I have found some generic ones on ebay for cheap. The front brain is telling me to go with a stock size replacement speaker while the back brain stereo afficiado is saying, "buy the 8" Pyles, you'll be glad you did". I know, I know. I'm not 18 anymore, heck I don't listen to the same music anymore. I may stretch a little and go up a size to 6.5". I'm thinking Polk Audio now. The front ones, I'll have to ponder on a while longer. I saw were Polk Audio had a 4"x8" two way that might be made to fit the front kicker without to much trouble. It's all noise anyway when your driving with the top down. More on this later.
