1991 chokes or Boggs down randomly
Old 10-11-2017, 07:05 PM
Marcus123
Marcus123's Avatar
Default 1991 chokes or Boggs down randomly
My 1991 chokes out or acts like it isn't getting fuel or air randomly could it be my fuel filter or maybe some type of maf sensor there's some weird sensors connected to my air intake that might be it but idk what do you guys think is there some sort of choke system that could be failing thanks for your help in advance
Old 10-11-2017, 07:28 PM
billschroeder5842
Zen Vet Master Level VII
Support Corvetteforum!
billschroeder5842's Avatar
Received 1,143 Likes on 846 Posts
Welcome!
In order to help, it is best to give more detailed information.
Does it idle ok"
When does the bog happen; normal acceration or heavy acceration?
Have you done any work to the engine?
How are your settings? TPS? IAC is your TB clean?
What is the general condition of the fuel system- filters, pump, etc
Stuff like this helps.
Old 10-11-2017, 07:35 PM
Marcus123
Marcus123's Avatar
If I have acceleration it usually gets rid of it and it's all stock the fuel pump was replaced by the guy I bought it from a year ago and the filter I haven't checked it. It happens really randomly usually after I just start it up and begin to drive but then there will be days or weeks before it happens again the check engine light comes on when it happens I checked the codes but couldn't find a good site that would tell me what the codes were
Old 10-12-2017, 06:00 PM
ddahlgren
ddahlgren's Avatar
There are many sites and may even be here or a link to one Google OBD I codes and bet yu will have many choices. Here is a start
http://www.gmtuners.com/OBD1_DTC.htm
Old 10-13-2017, 12:03 AM
aklim
aklim's Avatar
Received 2,254 Likes on 1,960 Posts
Lets assume he did. Question is, with what? Replaced with a junkyard one or a quality one? Better yet, let's test it. Let's see if it will pressure up quickly and hold pressure.
You say you got codes. What are they?
To 1991 chokes or Boggs down randomly
Quick Reply: 1991 chokes or Boggs down randomly
