Switched power source
Old Oct 12, 2017 | 05:10 AM
TnEBill's Avatar
TnEBill
Default Switched power source
1989 Vette. Looking for an ignition controlled power source under the dash, that's easy to access, and has sufficient load capacity to power a couple of add on electric gauges. Thoughts anyone?
Thanks!
Old Oct 12, 2017 | 10:53 AM
c4cruiser's Avatar
c4cruiser
You should have a harness under the center console that has a always hot wire, ignition controlled hot wire and a ground wire. The two hot wires are rated for 10A each.
Old Oct 12, 2017 | 11:00 AM
WVZR-1's Avatar
WVZR-1
I don't think for the OP's '89. I thought that came later. I'd like to be wrong here! '91 maybe same as the DAB (Delayed Accessory Bus) I thought.
Old Oct 12, 2017 | 07:46 PM
ddahlgren's Avatar
ddahlgren
Electric meter movements and sensors should only use mili-amps.
Old Oct 12, 2017 | 10:19 PM
WVZR-1's Avatar
WVZR-1
Originally Posted by ihatebarkingdogs
First year for the power wires in the center console is 1992.
Nope - '91 for sure.
ORANGE wire fused w/B CONV that includes Cigar lighter different wire(HOT ALL TIMES), PNK/BLK fused separately as I CONV(HOT IN RUN). Both fuses are in the AUX 2 BOX. I actually looked to be sure. I'm quite sure it's in the '91 Owners Manual also.
Old Oct 12, 2017 | 11:59 PM
aklim's Avatar
aklim
Saw mine when I took that area apart for some reason or other.
Old Oct 13, 2017 | 12:29 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
OP, i used the radio power that is switched. off the too of my head i cannot remember what color it was!
Old Oct 16, 2017 | 09:01 PM
TnEBill's Avatar
TnEBill
I was just going to ask if the radio power feed had sufficient current to suffice. If it worked for you, probably does. Thank you!
Old Oct 17, 2017 | 01:31 AM
Hot Rod Roy's Avatar
Hot Rod Roy
The radio power circuit will be hot in both run and accy positions. I doubt that would be the best for addl. gauges. I'd think you would want hot in run position only. Try your feed wire for ignition (probably pink), turn signal flasher, back-up lamp switch, or rear window defogger switch. Those wire colors for your car unknown to me.
To Switched power source
