glass top question
Old Oct 7, 2002 | 06:27 PM
qkvette's Avatar
qkvette
Default glass top question
what can i do, other than replace the complete top, to remove the hazing and webbing on the galss top. this is my second top, so i would hate to by another one. if i have to i will buy the fiberglass painted top.
thanks,
joel
Old Oct 7, 2002 | 06:40 PM
fullboogie
Default Re: glass top question (qkvette)
Joel-
Look into having the top professionally polished. I know that plastics can be "buffed out" using rouge and a buffing wheel. I used to work in a shop that restored the old 2-seater T-Birds, and we routinely polished tail light lenses, instrument cluster lenses, just about anything clear plastic. We could take something that looked terrible, and within a few minutes on the buffing wheel, make it look absolutely brand new.
I bought the stuff for my garage at Sears Hardware. Get a buffing wheel and a stick of rouge (made just for plastics) and have at it. You may be surprised at how nice it turns out. If that doesn't work, take it to a pro.
Old Oct 7, 2002 | 06:52 PM
MIke350's Avatar
MIke350
Default Re: glass top question (fullboogie)
im sure you could just paint the top the same as the body color, and then the inside black maybe :smash:
Old Oct 7, 2002 | 07:35 PM
qkvette's Avatar
qkvette
Default Re: glass top question (MIke350)
i was thinking about getting it painted at my buddies shop. do you guys think it will work ?
i also read about buffing & polishing it from corvette fever. i may try this before painting.
thanks again,
joel
joel
Old Oct 7, 2002 | 08:24 PM
kspurr's Avatar
kspurr
My top looked horrible when I bought the car, and I really wanted a painted top, so I figured I may as well try buffing the haze out. It was already ugly, so how much worse could I make it.
Well, it looked great after spending about 4+ hours wet sanding it by hand moving through all the grits of paper I had in my garage up to 2000 grit. The top was finally totally smooth, but I had to really work at it with some fine polishing compound to get it to shine again.
You also have to be careful with the metal around the acrylic, as it is painted black and the paint will come off. You may just want to plan on masking the acrylic off later and repainting the metal black if it gets scratched up.
Good Luck!
Old Oct 9, 2002 | 01:02 AM
qkvette's Avatar
qkvette
Default Re: glass top question (kspurr)
do you think it is safe to use a power sander/polisher ?
thanks again,
joel
Old Oct 9, 2002 | 04:38 AM
paintdaddy's Avatar
paintdaddy
Is it crazed or scratched? if its crazed ,youll have to replace it,or paint it ,which I think would look cheap.If it is scratched,you can have it polished .I think the rule of thumb is if you can feel the scratch with your finger nail,it cant be polished. :yesnod: :seeya
Old Oct 9, 2002 | 11:20 AM
Jim D's Avatar
Jim D
Default Re: glass top question (paintdaddy)
If you do a search on my signature, you will find the instructions for refinishing your top, good luck Jim.
Old Oct 10, 2002 | 02:55 PM
qkvette's Avatar
qkvette
Default Re: glass top question (Jim D)
The top looks like a thin film is comming of the top, and you can peel it off with your finger nail.
I did a search on your name Jim and I found the procedure to refinish the top. I really don't have anything to lose except time, so might as well try it.
thanks again for all the info.
Joel
Old Oct 10, 2002 | 04:45 PM
cire96's Avatar
cire96
When mine got hazy, I took it to a local body shop. They wet sanded it with 800 grit, then buffed it with two wheels and polloshing glazes of lessening agressiveness until it looked like new. It too about an hour and cost me $50. Good luck. Cire96
To glass top question
