89 C4 cooling problem
Cruising
Recently I've had a problem with my cooling system, I'm assuming coolant wouldn't circulate through the engine unless I was on the throttle a lot. My coolant temperature would hit 240 degrees and would drop back down to 190 after I lay on the throttle for a few seconds. I replaced my radiator, water pump, thermostat, and serpentine tensioner and so far the problem is still there. I did buy a cheap water pump, about 50$ so I'm banking on it being that. I'd like the some advice before I go tearing the ac compressor and fuel lines off again. Should I try a hi flow water pump?
Hopefully you've read the sticky on the cooling system. If not read it.
You cannot cool an engine 50 degrees in "a few seconds". So if you are really seeing that it could be an indication problem.
Basics, Check and clean the radiator (aka road vacuum). Check the fan operation.
Cruising
When you replaced those parts, did you also replace the radiator coolant hoses? Could be that one or both are collapsing. That cuts off the coolant flow and temps go up.
Also make sure you clean out the junk that collects between the A/C condensor fins and tubes. If the condensor is clogged up, that cuts airflow to the radiator. Look up under the front to check for junk that may be clogging the condensor and not letting air get to the radiator.
Are the air dam pieces in good shape? The air dam is what directs airflow up to the condensor and radiator.
Cruising
Cruising
The radiator fan doesn't turn on til 238*. Are you sure there is anything "wrong"? There are ways to make these run cooler, but if yours is mostly stock, that's about where they run.
240 isn't unusual for Calif driving. My 89 would climb in traffic. Would not cool down until I was moving. If it is a head gasket, when fixed, replace that stupid little aux. fan in front of condenser with a 14 inch pusher fan. Then wire it to a switch so you can control when your fans come on.
I also put a Becool radiator in.
Good luck
Good luck
Cruising
Good luck
Good luck
