window guide
Old Oct 22, 2017 | 06:53 AM
preacher putz's Avatar
preacher putz
Default window guide
96 collectors edition, passenger side electric window. The front guide
broke, I now have the replacement part.
The bolt goes into the new guide and instead of a nut on the back there appears to be a threaded flat disk.
How do you remove the bolt?? is there a special tool? if so what is it
called and where do you get one?
Once again thanks for your help
Pr. Putz
Old Oct 22, 2017 | 08:30 AM
WVZR-1's Avatar
WVZR-1
Pr. Putz
You either need the correct "spanner socket/wrench" OR you can grind/dremel a socket that you have to work. You could visit a local glass shop and see if they have. You should have no problems. Grinding/dremel one that you have now is generally the least expensive.
There are specialty sockets.
Old Oct 22, 2017 | 09:31 AM
9T3VETTE's Avatar
9T3VETTE
Harbor freight sells a cheap wrench that works perfectly.
https://m.harborfreight.com/adjustab...not%20provided
Old Oct 23, 2017 | 11:26 PM
MatthewMiller's Avatar
MatthewMiller
Yep, that worked for me.
Old Oct 24, 2017 | 02:56 PM
Dt86's Avatar
Dt86
Or
Old Oct 25, 2017 | 09:24 AM
VenkmanP's Avatar
VenkmanP
Right angle needle nose pliers.
Old Oct 25, 2017 | 05:50 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
In answer to the OP question:
Snap-on does make the exact tool that you need. It's actually a 3/8 socket part # S9610 called a window sash-nut spanner. It's $24.00
I bought it when I had to replace the driver side window regulator as well as the window guide. Not being a mechanic it was worth it to me. Saved me a lot of time and aggravation and most likely at some point the passenger side will have to be replaced and I'll be even happier that I have it.
Old Oct 25, 2017 | 09:03 PM
RUU's Avatar
RUU
Similar item also available from Corvette Central for $15. Part # 283035
Old Oct 25, 2017 | 11:43 PM
Mr. Peabody
Wish I had seen that when I was looking. Probably would have gone that way.
To window guide
