Regular or premium????
Old Oct 29, 2017 | 07:45 AM
PatternDayTrader's Avatar
PatternDayTrader
So one of you should be able to explain 110 octane gas.
Old Oct 29, 2017 | 08:04 AM
B757captain's Avatar
B757captain
That was the question that made me look it up. Octane ratings close to 100 or above 100 are achieved by adding MTBE or tetra-ethyl lead. Good article here:
https://science.howstuffworks.com/gasoline.htm
Old Oct 29, 2017 | 08:28 AM
PatternDayTrader
Yeah it basically says the chemical equivalent of octane/heptane, so its not actually octane and heptane plus trace chemistry. Instead, that's just how its measured or rated. So 110 octane fuel would have the combustion properties as 100 percent octane, that's concentrated by 10%, and no heptane. Simple.
Old Oct 29, 2017 | 09:11 AM
Purple92's Avatar
Purple92
The fact is that there are a lot of different things going on with car engines. I have known people at work who had cars that were apparently so carboned up - that engines that were rated to run on regular needed premium to avoid significant knocking - one of these was a Ford V-8 and another was in a Subaru 4 Cyl. You would think the knock sensors would tell the EFI Computer to intervene - but apparently not - no check engine light on - so presumption is that the knock sensor was OK ...
Tom400FI - the engine I was referring to was a late 1990's Ferrari with a very high compression ratio. One of the people I spent time with at the track related a story where the engine in an acquaintances car was badly damaged (supposedly several cracked pistons, & Yes, it was supposedly being run at the track) and Ferrari would not cover the damage under warranty saying the car was run on too low an octane.
Old Oct 29, 2017 | 04:27 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Copy that. Thanks! I figured that it might be some form of exotic car to be limited that way. In the case of a Ferrari, it both worth the cost...and probably not a cost issue!
Old Oct 29, 2017 | 05:04 PM
ddahlgren's Avatar
ddahlgren
There is a whole bunch more than just 2 chemicals in gas.
Old Oct 30, 2017 | 10:56 AM
clove86's Avatar
clove86
i have a 1991 l98
i did a complete tune up in the last year and advanced the timing to 7
stock advance is 6
my car knocks like mad at first start up if i run mid grade
i have found that i have to run premium.
the car is 26 years old too. so...got that going for me.
Old Oct 30, 2017 | 11:11 AM
whalepirot's Avatar
whalepirot
Part of start-up is a test of the knock sensor, with a brief timing advance and 'listen'. Most will never notice it.
Old Oct 30, 2017 | 11:59 AM
vader86's Avatar
vader86
Use what octane the engine requires, nothing higher. Higher octane does not equal better gas.
Best thing anyone can do is get familiar with a scanner/laptop, and check knock counts. If you see it knocking and the ECM pulls timing back, then you need to go up to the next grade of octane in your area. Otherwise you are just guessing. Relying on your hearing to detect knock only seems to work when the knock is particularly bad. Injector tick and rattling in a C4 is just too prominent to recommend relying on any of that for someone who doesn't know.
Old Oct 30, 2017 | 02:09 PM
DGXR's Avatar
DGXR
Every car has an owner's manual that will explain the fuel requirements.
Here are the basics for gasoline engines:
-- High-performance cars with forced induction or high-compression engines often *require* premium. Usually the gas fill door will say "premium fuel required" in huge bold letters, and these words will be displayed near the fuel gauge as well.
-- Some cars are "premium recommended" such as my 1995 LT-1 Corvette. The owner's manual says "use 91 octane or higher for best performance." The manual also says the engine will run OK on gasoline below 91 octane, although at reduced power levels, but do not run gasoline below 87 octane.
-- All other cars run fine on regular gasoline.
-- Direct-injected engines (GDI) warrant a separate discussion thread.
-- my gas mower will run on Bacardi 151
Old Oct 30, 2017 | 03:37 PM
clove86's Avatar
clove86
if i have mid-grade in my car now and i need 91 can i add a can of octane booster to help it? ideally?
Old Oct 30, 2017 | 03:57 PM
DGXR's Avatar
DGXR
You can, just be sure you know what you are buying. Most octane boosters that claim an increase of 3-4 points are not giving you full points, they give tenths. E.g. they will raise 87 octane to 87.3 or 87.4 octane.
There are a few products that will increase octane several full points, and they tend to be expensive "race fuel" type additives. Here is one that cost $29 per quart: https://www.maperformance.com/produc...el-concentrate
Obviously it's best to buy your octane at the pump when you can.
Old Oct 31, 2017 | 10:56 AM
  #33
3D-Aircrew's Avatar
3D-Aircrew
I've always needed 91 octane or else there is noticeable pinging. I got a 86 L98 5.7L.
Old Nov 1, 2017 | 05:56 PM
  #34
gdgeorge's Avatar
gdgeorge
Veteran: Marine Corps
Mid-grade (runs fine) or high-test if I'm not driving my 93 regularly.
Sent from the mobile client - Forum Talker
Old Nov 2, 2017 | 12:17 AM
  #35
topfuel67's Avatar
topfuel67
Yes, there is a lot more in gas than heptane and octane. The octane rating is based on the simple formula. Now there's Ethanol and a bunch of other additives. The 110+ octane race fuels use the mathematical formula for the rating. I had a super gas drag car with 13.75 CR and it used 116 race fuel. That stuff has a sweet smell to it, nothing like gasoline.
Old Nov 2, 2017 | 10:29 AM
  #36
DGXR's Avatar
DGXR
I have wondered how much additional timing (and power) would be available by adding a few gallons of 100 octane from the local Flyers gas station. I don't mean a fill-up, not at $8 per gallon, but a few gallons to raise the octane in my tank from 91 to about 93 or 94.
Anyone done this, and able to compare how the LT1 or LT4 performs differently between the two (91 octane and 93/94)?
Old Nov 2, 2017 | 10:47 AM
  #37
gdgeorge's Avatar
gdgeorge
I don't have anything empirical on paper, and the car is faster than I drive. Having said that, anecdotally: I see no difference between the mid-grade and high-test except, perhaps, a minimal MPG improvement. Mixing the two doesn't seem to have any effect, and I wouldn't expect it to. I discovered that the car runs poorly on regular when SWMBO filled up with the stuff. The car demonstrated hard starting, hesitation, and run-on... As soon as I got the thing to half a tank, I added high-test and that resolved the issues immediately.
Best
Jerry
To Regular or premium????
Old Nov 2, 2017 | 10:52 AM
  #38
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
I always use 91+ but than I also have 11 to 1 compression.
Old Nov 2, 2017 | 10:59 AM
  #39
DGXR's Avatar
DGXR
Best
Jerry
Thanks Jerry. I have also run regular 87 octane and mid-grade 89 octane which resulted in decreased power and a bit of extra pinging but nothing major. There was no hesitation or hard starting that I noticed.
I was wondering specifically about performance boost (if any) when going from 91 octane to 93 octane... not dyno numbers, just general SOTP impressions of "better performance"
Old Nov 2, 2017 | 11:23 AM
  #40
gdgeorge's Avatar
gdgeorge
Understood. In that case, no. I have not noticed a performance difference between the mid-grade and high test gasolines in the BaltoWash area.
Best,
Jerry
