Regular or premium????
Old Oct 27, 2017 | 06:56 PM
lectroglide's Avatar
lectroglide
Default Regular or premium????
Old Oct 27, 2017 | 07:08 PM
383vett's Avatar
383vett
Get the good stuff unless your just running groceries.
Old Oct 27, 2017 | 07:32 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
I run premium in everything I have ever owned.
Old Oct 27, 2017 | 07:34 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I run 85 in everything I own except for my "high" compression engines; the LT1 and the LS6.
The other engines don't need it...waste of money.
Old Oct 27, 2017 | 09:08 PM
HAD2HAV2's Avatar
HAD2HAV2
Depends on the engine. My 88 L98 runs great on reg. Best reg. gas you could buy was from AMACO. I think it was clear in color(white gas). I bet the LT engines would prefer High Test. I'm giving my age away.
Old Oct 28, 2017 | 03:21 AM
Joe C's Avatar
Joe C
(85 L98) street driven DD - I switch from plus to premium, back and forth, without any rhyme or reason. can't say I notice any difference. if I do, it's minimal.
Old Oct 28, 2017 | 06:44 AM
Bentsi's Avatar
Bentsi
Funny, my daily driver is a 2017 Volvo S90 T6 and I fill it with regular, the 95 Corvette, 79 Camaro and 69 eldorado gets premium.
Old Oct 28, 2017 | 07:12 AM
ddahlgren's Avatar
ddahlgren
Just put in what the owners manual asks for. Most have it printed near the filler cap as well.
Old Oct 28, 2017 | 07:36 AM
PatternDayTrader's Avatar
PatternDayTrader
I run regular in all my cars including my 95 lt1. I am not hard on the engine at all. Basically all highway cruising above 70mph. Regular is fine under these conditions.
Old Oct 28, 2017 | 10:06 AM
Purple92's Avatar
Purple92
If the manufacturer calls for a certain octane level - run that level as a minimum.
In very simplified terms - octane can be considered "resistance to detonation". In truth there is ever so slightly more energy in a gallon of 87 octane than there is in a gallon of 93, but the difference is noise for most of us... However - in many cases the additive package in the higher octane gas is substantially better than what's in regular. The additive package is supposedly most of what the "Top Tier Gas" stuff is all about.
Sure most cars with a decent EFI system will operate on lower octane gas - but the knock sensors will constantly be signaling knocking, and in response, the computer will pull timing - primarily when you are "on" the gas. If you purchased a Vette - the odds are that you like a car that corners, and has decent power. IMHO - It doesn't make a lot of sense to do something (use lower octane gas) that will limit the power the engine will make when you paid extra specifically for that.
I will also say that there are a few engines out there (none are found in C4's) that simply can not live on less than the specified octane - their mechanical compression ratios are just too high (along with the specifics of the combustion chamber design), and the lower octane gas will create pre-ignition even without a spark - no EFI system I know of can correct for that.
Old Oct 28, 2017 | 10:09 AM
whalepirot's Avatar
whalepirot
Now, there's a concept. I follow what my cars' documents call for, usually with little or no discernable effect if running a lower grade.
The ECM will detune as needed for lower octane, affecting MPG and performance. I was surprised to see my 11:1 engine run okay, even up a challenging, loooong mountain climb, with no real complaints. This, when the sole station was out of everything but regular. then, it wasn't REAL hot outside and it wasn't anymore than a highway cruise.
I agree with an article I read. stating "running premium in a recommended-regular engine just wastes money".
Old Oct 28, 2017 | 11:04 AM
topfuel67's Avatar
topfuel67
What people don't realize is what octane actually stands for. Gasoline is basically a mix of heptane and octane (yes there's other additves). Heptane is an incredibly volatile explosive compound. Octane is the opposite. So in simple terms 87 octane gas is 13% heptane and 87% octane. 91 octane gas is 9% heptane and 91% octane. I've demonstrated this by pooring octane boost on the ground and tried lighting it with a lighter. Nothing happens. It doesn't burn.
​​​​​​So for a high compression engine or any forced induction engine 91+ octane is needed to keep the combustion down as the high compression makes up for it. A low compression engine needs 87 octane as the 91 or higher doesn't have enough bang.
Old Oct 28, 2017 | 11:27 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
1. I've SHOWN that the additive package in cheap, grocery store gasoline is better than good enough. The additive packages minimum standards are set by the Gov't and better than good enough.
2. Timing will only be retarded IF the engine actually requires/needs higher octane. L98's, L83's, L33 (vortecs) for examples, don't. I read an article once that claimed that GM found that the LT1 produced exactly the same HP on 87 as 91 (during development)...which indicates to me that I'm wasting my own money with 91 in the 'Vette.
3. What engines out there are you talking about? I have never seen or heard of an (EFI) engine that won't that won't live on pump gas.
Old Oct 28, 2017 | 12:17 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I think it depends. How's that for not going one way or the other.
If the engine needs it to prevent preignition then use the premium. If it does not, then use the regular and don't waste the money.
For L98's. I had an '88 Corvette that would ping badly with regular gas. It needed premium. While my '85 and '87 I couldn't tell any difference.
For LT1's. I had two '94 Corvettes that I couldn't tell any difference with regular or premium, but my '95 Corvette does not run as well with the regular. It retards timing and I get poorer performance and mileage.
My '96 LT4 states Premium Fuel Only instead of Premium Recommended. I have only used premium with it.
I suspect that like Tom400CFI said, an EFI engine should live on pump gas. But it may be at reduced performance. Under light loads I suspect most will run normally.
In practice I use premium in my current Corvettes unless it is not available.
Old Oct 28, 2017 | 01:10 PM
ctmccloskey's Avatar
ctmccloskey
Default Pinging on the L-98 engine
I have a 1988 Coupe that runs great on the 87 octane gas available here in Virginia. I have never heard the car ping or heard any unusual noises from the engine running regular.
Nowhere on my car does it tell you to use Premium fuel.
If your L-98 engine is pinging it is probably because your engine has carbon in it. Even an air cooled VW engine will ping when carbon is present in the cylinder heads. The solution on a VW was to slowly pour cold water into the carburetor while running at about 1500-2000 rpm. The thermal shock would break loose the carbon chunks and the exhaust would spit out the carbon. I have done it many times on VW's and always had good results.
On your 1988 L-98 I would buy a can of BG 44-K and run it through your fuel system. It might take two to get it all but the BG product works very effectively at removing deposits in the cylinder head. While running the additive in your gas be sure to "drive it like you stole it".
I routinely run Sunoco 87 octane gasoline in my 1988 Coupe and that seems to be sufficient for that engine or at least my engine.
Good luck and happy motoring! (Without the pinging)
Old Oct 28, 2017 | 01:44 PM
mickey5's Avatar
mickey5
Does anyone have info on how a fuel octane rating changes with age? I've read somewhere that after 6 months of storage there is a degradation in octane. Before I store the Vette for the winter I fill with premium so come spring I get good performance with the old fuel.
Besides that, when I open the fuel lid it says "premium recommended" next to the cap in english and french.
Old Oct 28, 2017 | 02:35 PM
lectroglide
Am surprised to see all the interesting comments here I have a 95 and run mid grade but also dump in a bottle of techron just for kix no complaints at this point.
We can read and listen to a million storys but the proof is in how the car performs
To Regular or premium????
Old Oct 29, 2017 | 12:25 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I changed head gaskets in my brother's, wife's Subaru Outback today. With this thread fresh in my mind, I snapped a couple shots of the intake valves. Remember the "techron" ads and the Shell "nitrogen" ads for clean valves?
My SIL's Subies' valves look better than the "clean valves" from those commercials; 90k miles, 87 octane gas.
IDK where they got their "lower quality fuels". (?)
Old Oct 29, 2017 | 04:15 AM
STL94LT1's Avatar
STL94LT1
I data logged a friends 1994 LT1 running 87 octane. It was constantly pulling timing, even at idle.
Old Oct 29, 2017 | 07:31 AM
B757captain's Avatar
B757captain
I read this and thought - too simplistic, must be bs . I have learned (sometimes the hard way) over the years that maybe I'm not always right and should listen and learn, so I looked up your information, and you, sir, are correct!! Kudos for teaching me something new today!
