oil pressure gauge
Old Oct 8, 2002 | 12:31 PM
Frank92's Avatar
Frank92
Default oil pressure gauge
the oil pressure gauge ist normal at idling but it jump erratic and then stay at full pressure while driving. car run great, no codes, maybe just ab bad oil press sensor ?
where is the sensor ?
thanks frank
Old Oct 8, 2002 | 08:03 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: oil pressure gauge (Frank92)
I know the oil pressure sensor is located on a fitting under the back of the distributor on a L98 but I don't know where it is on a LT1. Somebody help this guy.
Old Oct 8, 2002 | 09:28 PM
Red Dwarf's Avatar
Red Dwarf
Frank92,
The pressure sensor & fuel fuel pump switch are located on the top rear of the engine. Can't find a good picture in the manual. There is a tee fitting with 2 adapters. It appears the oil pressure sensor is either verticle or to the right looking forward. Don't have my car here, unfortunately. That shud be a start for ya. I'm gonna have to get a scanner one of these days. Hope this helps.
Old Oct 9, 2002 | 03:36 PM
Frank92's Avatar
Frank92
Default Re: oil pressure gauge (lou sylvestri)
i´ll watch out if i can find it. i hope it´s nothing serious. i think there is something wrong with gauge/SENSOR.
thanks frank
To oil pressure gauge
