1994 Corvette
Old Nov 9, 2017 | 01:05 PM
franklins4him's Avatar
franklins4him
2nd Gear
Default 1994 Corvette
I have a 1994 Corvette with no spark. Coil has been changed, opti spark distributor, and wires, plugs, and no spark. Any suggestions
Old Nov 9, 2017 | 02:47 PM
belairbrian's Avatar
belairbrian
Hopefully you've checked fuses. So time to troubleshoot the ICM.
Old Nov 9, 2017 | 02:56 PM
JimLentz's Avatar
JimLentz
Are the fuel injectors doing anything?
Old Nov 9, 2017 | 03:31 PM
s carter's Avatar
s carter
If you have already thrown in all the expensive Parts it is time as suggested go back to the basics, Fuses, Flow Charts in the FSM.
(a new Opti Doesn't always mean a good one)
One thing I had happen to me I installed a new Opti and the car started ran smooth Topped off Coolant. and started to do a little wire clean up and put Air cleaner Tube back.
While putting the Wire Loom back around the ICM & Coil Wires car cut off NO SPARK wiggled ICM&Coil wires while cranking car started, found one coil lead Questionable and same with 1 or 2 wires on the ICM replaced the pigtails for ICM & Coil all is well now a year.
Old Nov 9, 2017 | 05:30 PM
Purple92's Avatar
Purple92
I agree with the other posters - You need to go back to basics, and check to see if you have power - do you have a signal to the injectors, do you have a check engine light on, do you have a spark at the coil output ???
If you do a search on this part of the forum - I've previously posted instruction on how to determine if the opti is doing what it's supposed to - basically you get the 4 wire connector that is clipped to the pass side of the intake, and backprobe the 4 wires while having someone crank the engine over. One wire is V+, one is ground, one is the hi-res output from the opti - the other is the low res output. If you have a DVM, and you have power and ground - you set the DVM to measure frequency and see if you are getting anything on the low res or high res while cranking.....
Old Nov 11, 2017 | 04:28 PM
pcolt94's Avatar
pcolt94
What was the original problem?
Was the engine running before you replaced all these items?
Need to check for 12 volts on the coil where it should be.
Need to check for the PCM output to the ICM. Should be 1-4 VAC while being cranked. It's the white wire, terminal "B" of the ICM. If there is no drive, then there is no spark. If there is drive, then possible ICM problem.
If you don’t know how to make these tests, ask for specific directions.
To 1994 Corvette
