1984 Vacuum ??
Old Nov 10, 2017 | 10:09 PM
red vet man's Avatar
red vet man
Default 1984 Vacuum ??
Where can I find a routing diagram of all the vacuum hoses and connections on the motor, fire wall, under the dash, everywhere on a 1984 corvette .
Old Nov 11, 2017 | 09:27 AM
belairbrian's Avatar
belairbrian
Short term
Autozone has them in their repair help section.
You need to sign up and login to see them.
For some reason the 84 diagram shows up when I select my 92.
Long term
Get a set of Factory Service Manuals
Old Nov 11, 2017 | 12:29 PM
383vett's Avatar
383vett
The FSM will allow you to rebuild your car from the ground up.
Old Nov 14, 2017 | 03:07 AM
Cliff Harris's Avatar
Cliff Harris
I found this is Google Images:
Old Nov 18, 2017 | 08:56 PM
red vet man
Default Thank you for your help
This is exactly what I need
Old Nov 19, 2017 | 01:43 AM
Hot Rod Roy's Avatar
Hot Rod Roy
It took me a while to figure out how the vacuum motors and inlet air flaps operate in the air cleaner, since there are two inlet flaps and only one temp sensor. This isn't explained in the FSM.
When the engine is running, and the temperature is cool, the temp sensor valve is open, so vacuum is applied to both vacuum motors, which closes both flaps. Warm air is therefore pulled from the exhaust manifold "stove" into the LH air cleaner inlet.
When the engine warms up, the temp sensor closes and the LH flap opens, allowing cool air to flow into the air cleaner from the LH hood duct. Since there is still vacuum on the RH vacuum motor, the RH flap stays closed and no air flows from the RH hood duct.
When the engine vacuum drops due to acceleration or full throttle operation, the RH flap opens and cool air is drawn thru both hood ducts.
Wierd!
Old Nov 22, 2017 | 12:09 PM
whalepirot's Avatar
whalepirot
Not much at all about vacuum in it, is there. My FSM is a very early ed., even having info on carburetion, but that's another thread of know-it-alls.
Again, nice work, Roy. Those who know you appreciate your breadth and depth of knowledge.
Old Dec 13, 2017 | 08:16 PM
red vet man
Thanks for all your help
To 1984 Vacuum ??
