Code 36 MAF burn off
Old Oct 9, 2002 | 12:09 AM
Silver89's Avatar
Silver89
Default Code 36 MAF burn off
Anyone have any ideas on what to do here?
I've already replaced both relays, but it's still showing the code.
:confused:
Old Oct 9, 2002 | 12:10 AM
scorp508's Avatar
scorp508
Have you unplugged the battery for 5 mins yet?
Old Oct 9, 2002 | 12:28 AM
vader86's Avatar
vader86
Hopefully, its not the MAF, which could cause the relays to go out again if it was the real problem in the first place.
And if the MAF goes, theres no guarantee itll throw a code for itself.
Old Oct 9, 2002 | 12:34 AM
scorp508's Avatar
scorp508
Another question, did you get the right relays? The C4s switched part numbers and relays many times for these things. 85 is totally different from 86 which is totally different from 87. I don't know about the other years.
Old Oct 9, 2002 | 01:07 AM
Silver89's Avatar
Silver89
Default Re: (scorp508)
Scorp & Vader... Thanks :D
Unplugged her for a few mins and everythings fine now :yesnod:
Didn't say anything about that in the service manual :rolleyes:
Old Oct 9, 2002 | 01:14 AM
scorp508's Avatar
scorp508
No it doesn't does it. :D I had a rogue code 36 pop up when I was playing with my MAF two days ago. I couldn't even get the damn thing to clear with a Snap-On MT2500 scanner. I would clear it and it would come back instantly. Unplugged the battery, all gone now and hasn't been back. :)
Old Oct 9, 2002 | 10:21 AM
Blue88's Avatar
Blue88
Default Re: Code 36 MAF burn off (Silver89)
I kept getting Code 36 and replaced both relays. I disconnected the battery for a few minutes and it still came on. After troubleshooting the connections and wiring harness I finally fixed it by unplugging the computer and plugging it back in. The service manual said that if all else fails to try unplugging and reconnecting the plugs to the computer and this did the trick. Last resort was to replace the ECM.
Old Oct 9, 2002 | 11:42 AM
Silver89's Avatar
Silver89
Default Re: Code 36 MAF burn off (Blue88)
I only ran it for a few mins last night, but prior to battery disconnection, it would come on after about 5 seconds. I'll keep this in mind incase it comes back. Thx. :)
To Code 36 MAF burn off
