Predicting Valve Float
Old Nov 21, 2017 | 01:00 PM
CMiller95's Avatar
CMiller95
Default Predicting Valve Float
I would like to hear your opinion on when valve float would occur with a given configuration. I know this is extremely subjective but here it is:
Cam: 220/226 @ 0.050, 0.530 lift, 113 LSA
Springs: PAC 1219, 160 closed, ~320 open
Valves: Factory
Pushrods: One Piece Comp 5/16'' hardened
Rockers: Scorpion 1.5 RR
Studs: 7/16'' ARP
I know that rockers and studs are really that relevant but I would like to hear your opinions
Colton
Old Nov 21, 2017 | 04:48 PM
ddahlgren's Avatar
ddahlgren
With that short a cam suspect out of breath by 6000 to maybe 6500 and the springs should go that far easily. Revs beyond that is probably just burning gas and making noise.
Old Nov 21, 2017 | 07:14 PM
CMiller95's Avatar
CMiller95
You're absolutely right about the cam range. Peak power was right at 6100 so its a loss after. Although shift point wise by time the shift light turns on and I react I'll be closer to 6400-6500. Just wanted some opinions on when valve float becomes a possibility.
To Predicting Valve Float
