Digital AC control problem
Old Oct 9, 2002 | 05:55 PM
TALMADGE's Avatar
TALMADGE
Default Digital AC control problem
Is there a solution to this problem. The digital reading on the AC controller likes to blink on and off at times. I can tap on the front panel and it will quit blinking on and off. Has anyone had this problem and is there a simple solution in fixing the blink, blink.
Old Oct 9, 2002 | 06:00 PM
Siveck's Avatar
Siveck
Default Re: Digital AC control problem (TALMADGE)
Yes, and all you need once you get the controller out is a pencil eraser. I just did this on my '89. Remove the climate control. Remove two clips and pull the circuit board out. Now rub the contacts where the board plugs into the face panel with the eraser until they are shiny. I reccomend changing the 3 bulbs while you are here. They are GE 37's. Enjoy!
Old Oct 9, 2002 | 06:13 PM
TALMADGE's Avatar
TALMADGE
Default Re: Digital AC control problem (Siveck)
Thanks Sivack, seems easy enough, good thought on the bulbs while in there, I have one burnt out. Agian thanks :)
Old Oct 9, 2002 | 08:28 PM
dizwiz24's Avatar
dizwiz24
do a search under recent topics posted by me 'dizwiz24'. I just explained how I fixed mine
Old Oct 10, 2002 | 07:54 AM
TALMADGE's Avatar
TALMADGE
Default Re: Digital AC control problem (dizwiz24)
Thanks dizwiz24, this is going to be simple, going to work on it tomorrow night.
Old Oct 10, 2002 | 08:23 AM
vette87's Avatar
vette87
You don't have to remove the climate control unit, just remove the clips and take off the face plate, clean the connector and your done.
To Digital AC control problem
