91 Fuel issue
Old Nov 24, 2017 | 02:34 PM
JBJrC4's Avatar
JBJrC4
Default 91 Fuel issue
I've been having problems keeping my car on. It'll start then die, sometimes it'll last a while on before dying. I've installed a new fuel pump, fuel filter, and plugs. I checked the fuel pressure regulator and it appeared normal. No tears or anything. So can I say I have an injector problem? Reason I say it's a fuel issue is because if I spray starting fluid it'll start then die.
Old Nov 24, 2017 | 03:42 PM
ddahlgren's Avatar
ddahlgren
Get a noid light and see if the injectors are firing.
Old Nov 27, 2017 | 08:07 AM
woody41's Avatar
woody41
I had a similar issue with my 91, if injectors and fuel system check out OK check your cats. If they are the original, one or all may be clogged and/or collapsed. That was issue with mine, both of the pre-cats were done. Mine would start and as soon as you touched throttle engine would die. Replaced the 3 with a single high flow cat and new mufflers and pipes, runs like a new one.
Old Nov 27, 2017 | 11:22 AM
aklim's Avatar
aklim
Sounds to me like the problem lies in the fuel. Either pressure or injectors. As suggested, get a noid light and see if the injectors are firing. If they are, they are shot. If not, look upstream
Old Nov 27, 2017 | 11:25 AM
JBJrC4's Avatar
JBJrC4
I checked the resistance of the injectors and four checked out bad.
Old Nov 27, 2017 | 11:27 AM
aklim's Avatar
aklim
https://fuelinjectorconnection.com/c...d-rail-o-rings
Change the regulator diaphragm while you are there and fuel filter.
Old Nov 27, 2017 | 11:30 AM
JBJrC4's Avatar
JBJrC4
Those injectors are on the way. I have changed the fuel filter, and the fuel pressure regulator checked out fine, but I plan to replace it once I get some money.
Driver side resistance
18.0
06.603.510.5
Passenger side
18.010.518.018.0
Old Nov 27, 2017 | 11:40 AM
aklim's Avatar
aklim
18.0
06.603.510.5
Passenger side
18.010.518.018.0
You are taking the manifold off and the diaphragm is cheap. Might as well replace the old rubber since you are there already.
https://fuelinjectorconnection.com/c...and-spring-kit
I wouldn't want to have to go back in and pull everything out.
While you are there, get a new set of gaskets for the TB. Take the IAC and the IAC housing off, clean the passages. Don't forget the top plate. Put everything back with fresh gaskets.
Old Nov 27, 2017 | 11:43 AM
JBJrC4's Avatar
JBJrC4
That's true, but yes I will wait to install the plenum to be able to purchase the regulator and install that. I'll clean the throttle body and iac. I ordered the same injectors you linked with the new gaskets and o rings.
Old Nov 27, 2017 | 11:46 AM
aklim's Avatar
aklim
Might as well do the coolant bypass to make it neater and easier to remove next time
Old Nov 27, 2017 | 11:47 AM
JBJrC4's Avatar
JBJrC4
Coolant bypass?
Old Nov 27, 2017 | 11:49 AM
aklim's Avatar
aklim
Coolant bypass?
Look at the TB. Under it there is a coolant hose going in and out of the TB. It will get gunked up sooner or later and to properly clean it, the TB should be removed. That means another coolant spill. Might as well bypass the TB so that it can be easily removed. It takes a connector for the hoses.
Old Nov 27, 2017 | 11:51 AM
aklim's Avatar
aklim
http://garage.grumpysperformance.com...-bye-pass.169/
To 91 Fuel issue
