This is what happened......
Old Oct 9, 2002 | 09:29 PM
Hi-psi's Avatar
Hi-psi
Default This is what happened......
......to the old motor.
If you read some of my past posts about my motor overrev, I initiall thought a bent valve/pushrod. Then progressed the theory to a stretched rod bolt.
Well,...upon dissassembling the motor. Found out it was a cracked piston. A rather large piece of the piston broke off as you can see,...and basically bounced/knocked all around in the cylinder beating the crap out of the piston and the cylinder head. :eek:
Just another picture of parts I've broken........ :lol:
Old Oct 9, 2002 | 09:41 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: This is what happened...... (Hi-psi)
ouch thats ugly :(
Ender85's Avatar
Ender85
...from an overrev?
Old Oct 9, 2002 | 10:13 PM
Hi-psi's Avatar
Hi-psi
Default Re: This is what happened...... (marthpodi)
...from an overrev?
Stock rev limiter cuts fuel off.
Car buzzed to about 7500-7800 probably, went lean, detonation, cracked piston. Most of the damage you see there to the piston is due to the large chunk of the piston bouncing around in there after it happened.
Old Oct 9, 2002 | 10:19 PM
vader86's Avatar
vader86
damn :eek:
Old Oct 9, 2002 | 10:44 PM
JCAIRE2's Avatar
JCAIRE2
Wow, that really sucks. Good thing it didn't do more damage
J :seeya
Old Oct 9, 2002 | 11:40 PM
robblk90's Avatar
robblk90
Default Re: This is what happened...... (JCAIRE2)
:eek:
Old Oct 10, 2002 | 12:06 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
How did you over rev. it......racing or just sitting still and reving????
Like to know if possible...
thanks :D
Old Oct 10, 2002 | 12:29 AM
Hi-psi's Avatar
Hi-psi
Default Re: This is what happened...... (oldace84)
thanks :D
Missed 2-3 shift while racing.
Old Oct 10, 2002 | 05:53 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
So I guess the head is trash too which is the reason for the Canfields. Looks like the piece was in the combustion chamber a while to beat the piston up that much.
Old Oct 10, 2002 | 08:27 PM
Hi-psi's Avatar
Hi-psi
Default Re: This is what happened...... (Vette92)
Yup. The car was run a bit after it happened. Not driven really,...except up on a trailer, off a trailer, around a yard, and into a shop. The the car was run for maybe another combined 30min trouble shooting and replacing pushrods. Messed the head up about the same and did a number on the spark plug too.
Old Oct 10, 2002 | 09:12 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
:eek:
To This is what happened......
