Won't stay running
Old Nov 30, 2017 | 12:25 PM
philstafford's Avatar
philstafford
Default Won't stay running
My brother has an 85 that starts right up and as soon as he turns the key back to the run position it'll idle a couple seconds and die. If he holds the key in the start position it'll continue to idle but kinda rough. IT won't go above an idle. Do any of ya'll have any idea what might be causing his problem?
Thanks, Stafford
Old Nov 30, 2017 | 12:28 PM
81c3's Avatar
81c3
Is the battery fully charged? Has the alternator been checked for output?
Old Nov 30, 2017 | 12:38 PM
philstafford
He might need to replace the battery, it's over 2 years old. The alternator is charging great, 13.4 volts.
Old Nov 30, 2017 | 05:25 PM
playsdixie's Avatar
playsdixie
85 has a place for a pressure gauge on the passenger side rail....get one....fuel pump runs for two seconds....once you get oil pressure....that runs the pump....chances are it's running for 2 seconds and not starting again.....can't really tell until you get a pressure gauge on it....
To Won't stay running
