Rough Idle Nightmare
Old Oct 10, 2002 | 12:00 AM
Bruce H's Avatar
Bruce H
Default Rough Idle Nightmare
Help........
My 89 coupe has a rough idle. I've replaced air filter, fuel filter, Disb. Cap & Rotor, Ign. Coil, Pvc Valve, IAC Valve, readjusted idle per manual and this site, checked tps (.54volts) and still roughhhh.
I'm going crazy....I bought a EGR & EGR solinoid which I plan to install this weekend. I'm also thinking MAF(how do I test the MAF?) and maybe the ECM. I've also read in several posts that several people have their TPS set at .64volts. The manual says to set it between .54 and .75 should I move it up to .64volts?
The car runs great but when you come to a stop it feels like it may die. I'm getting frustrated.
Bruce H
:cry
Old Oct 10, 2002 | 12:09 AM
Bruce H's Avatar
Bruce H
Default Re: Rough Idle Nightmare (Bruce H)
I forgot to add that I repalced the MAf Power relay and Burnoff relay.
Bruce H
Old Oct 10, 2002 | 12:22 AM
aroulette's Avatar
aroulette
Have you done a full tune up? What about swapping O2 sensor? I did these things and seems to help
Old Oct 10, 2002 | 07:38 AM
jimbo10494's Avatar
jimbo10494
I have the same rough idle on my 87 coupe. Changed plugs, wires, cap, rotor, intake manifold gaskets, removed throttle body and cleaned IAC. Still runs rough at idle, feels like it wants to die. when you figure your problem out please e-mail me @ jimbo10494@aol.com, I will do the same if i figure mine out.
Old Oct 10, 2002 | 07:41 AM
jimbo10494's Avatar
jimbo10494
I have the same rough idle on my 87 coupe. Changed plugs, wires, cap, rotor, intake manifold gaskets, removed throttle body and cleaned IAC. Adjusted the TPS, Still runs rough at idle, feels like it wants to die. when you figure your problem out please e-mail me @ jimbo10494@aol.com, I will do the same if i figure mine out.
Old Oct 10, 2002 | 11:16 AM
Bruce H's Avatar
Bruce H
Default Re: Rough Idle Nightmare (jimbo10494)
Will Do JIMBO,
If I find the problem I'll let ya know.....I've checked the timing and it was right on the money. I'm going for the EGR valve next and then the o2 sensor. I should add that I have never got any codes for the rough idle. I'm running out of ideas, then it's off to the shop(OUCHHH)!!
Bruce H
:eek:
Old Oct 10, 2002 | 11:26 AM
aroulette's Avatar
aroulette
I took it to the shop and they said that is in normal for the year! Oh well.
Old Oct 10, 2002 | 11:30 AM
JonM's Avatar
JonM
I would check for vacuum leaks
Old Oct 10, 2002 | 11:37 AM
Greenvette's Avatar
Greenvette
I would try cleaning the throttle body. When the inside gets real guncky, it can effect the idle
Old Oct 10, 2002 | 12:19 PM
Siveck's Avatar
Siveck
.54V is correct for TPS. Check the resistance of your injectors. One of mine went bad and caused this. Its a common problem for the L98. With the harness unplugged, the original greenish-gray Multec injectors should read 16-17 ohms. Onee of mine was at 2.9 ohms. I unplugged it and the car ran great. Maybe time for new injectors.
Old Oct 10, 2002 | 01:36 PM
VetBoy89's Avatar
VetBoy89
I had the same problem for a long, long time along with an annoying code 33. I replaced all the common parts. .54v is correct for the TPS +/- .8v closed, and about 5v wide open. My TPS was set to .54v but wide open I could only measure a little above 3.3v. Thanks to the advice of this forum I replaced the TPS and both problems are gone. TPS is now set at .54v closed and about 4.65v wide open. Some people here were skeptical about the TPS being related to the code 33 but since 65Z01 said it could be related, it was worth the $35 risk to me to buy a new TPS from Autozone.
Just my .02 :cheers:
Old Oct 10, 2002 | 01:59 PM
vettmech's Avatar
vettmech
Default Re: Rough Idle Nightmare (VetBoy89)
even though the book says you may read up to 5 volts you never want to get there. when you are above 4.65 v or so the ecp senses what is called the deadband area and will sometimes set a code. same for the low side.... less than about .4 volts will set a code ........ Also I have gotten leary of the aftermarket tps....... they aren't sealed as good as the DELCO ones and will screw up after a good engine detailing...... They HATE Armorall.... :lol: :seeya
To Rough Idle Nightmare
