removing passenger carpet under the dash
Could some one please tell me how you removing passenger carpet the part that goes into the foot well from the air vents down got the drives side of ok but cant seam to see how to remove the other side
Gary Bagley (12-03-2017)
The carpet is attached to a part of the dash panel. Remove it as one piece. Removal is described in the 1990 FSM. If you need the page let me know and I will look it up.
Were you able to figure out your heater problem? Once I got my heater box out and tested the actuator it set a code 01 and would "pulse" when heat was requested. Just sent my programmer, control head and actuators to batee for diagnosis.
If you could give me the page that would be very helpful the head unit and programmer are at batee for repair as the programmer board had a part burnt out I want to test the wiring before refitting once I get them back seeing as I have sent them form the uk
Since you have your programmer removed, could you possibly take a picture of the silicon plug with the colored lines showing their position and post it? When I was removing my programmer the tan line came out of the plug and I don't know the correct port to attach it to.
The piece of carpet is attached to the upper trim pad (essentially the entire dash pad for the car). The removal of the upper trim pad starts on Pg 8C-14.
This one might have the better views
https://www.ebay.com/itm/Automatic-E...!US!-1&vxp=mtr
Try this from a later FSM
jrd1990zr1 (12-03-2017)
jrd1990zr1 (12-06-2017)
