With injectors unplugged, install a noid light.. Disconnect ECM. Does noid light blink when key is turned to run. The injectors are powered by a key on fuse. The ecm grounds them. I have experienced failures like this with non gm reman ecms.
With ecm disconnected one wire has constant 12 volts positive..no ground
If the injectors don't come on when key is turned to run with ecm disconnected, but will if ecm is connected. I would replace the ecm. There is a slight chance if the distributor was worn distributor could cause it intermittently, so you could see if there is play or wobble in shaft. You just need to try to shake rotor and see if it moves or wobbles side to side.
Could he disconnect the distributor and test to see if it does that? If it does, we definitely have an ECM issue. If not, maybe wobble it like you suggested?
Ok ..new ecm still 12 volts on plug for injectors...unhooked four wires from dist...still 12 volts on plug pos and neg on plugs....what else can it be
Sounds like a short in the injector wiring. Unplug ALL the injectors (all 8 are in parallel, so if one is plugged in it will look like a very low resistance). Measure from the light green wires to ground. Measure from the light blue wires to ground. Unplug the connectors from the ECM when you do this because the light green and light blue wires are connected together inside the ECM.
With ecm unplugged ..all injectors unplugged I have 12 volts positive to all plugs no ground with key on
The injectors are fused 12v (2 fuses right and left) when key is turned to run or start. With the injectors unplugged only one side of connector should have 12v. Since you have the injectors unplugged you could ohm them to make sure they are within spec.s. With the injectors plugged in their will be voltage on both sides, the circuit is looking for ground from ecm. If harness is shorted the injectors should have cycled when key was tuned to run with the ecm unplugged. An injector with low resistance will cause a miss in 3-4 cylinders on that branch. Current follows the path to least resistance, the lower ohm injector would be the least resistance. Open injector causes miss on that cylinder only. Do all injectors still cycle with key turned to run?
