What is the TB Bypass?
Old Oct 10, 2002 | 02:19 AM
DanielW's Avatar
DanielW
St. Jude Donor '04-'05-'06-'07-'08
Default What is the TB Bypass?
I know it's throttle body bypass. But what does it do to the performance or any other effects. The reason why I ask is because I work in a hardware store and some two guys came looking for some fittings and connectors in the plumbing department and they had a list of parts and instructions printed out for an "LS1 throttle body bypass" I asked them if it was a camaro, f-bird or a vette and they said it's a camaro. Also if you answer tell me how does it work in lamest terms. what happens once it is done. THANKS :cheers:
Old Oct 10, 2002 | 02:39 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: What is the TB Bypass? (DanielW)
Coolant is routed through the TB to prevent icing of the throttle plates in very cold and damp weather. Unfortunately this also heats the TB and plenum in all weather and heating the intake air is our enemy, when we seek as much HP as possible.
So we just remove the hose from either side of the TB, cap off the fittings and splice the inlet and outlet hoses together so that coolant still flows but not through the TB.
The bottom line, colder intake air means more HP.
Old Oct 10, 2002 | 09:40 AM
vader86's Avatar
vader86
Once the engine gets warm, it heats the intake charge with the coolant routed thru the TB, this isnt good for performance.
All you do is disconnect the two hoses on each side of the TB and mate them together.
Old Oct 10, 2002 | 11:37 AM
DanielW's Avatar
DanielW
Default Re: What is the TB Bypass? (vader86)
thanks :cheers:
To What is the TB Bypass?
