Can someone explain this for me
Old Oct 10, 2002 | 11:30 AM
VQT88Vette's Avatar
VQT88Vette
Default Can someone explain this for me
What the difference between Heavy Duty transmission and street/strip transmission? http://www.pro-built.net/index.cfm?f...t&categoryid=9
If I don't go tot he drag strip often, can I still buy the street/strip trans.?
Reliability between the two trans.?
Thanks,
Old Oct 10, 2002 | 02:27 PM
vettmech's Avatar
vettmech
Default Re: Can someone explain this for me (VQT88Vette)
The street/strip trans will be the one that chirps the tires going into second. The heavy duty one will have a more firm shift than stock but won't usually chirp the tires :seeya
Old Oct 10, 2002 | 03:11 PM
VQT88Vette's Avatar
VQT88Vette
Default Re: Can someone explain this for me (vettmech)
Thanks vettemech, you were right about changing the shift linkage seal on the weekend so I have a whole day to clean the oil pan :rolleyes:. The horizontal shaft was pretty hard to take out and the 1/4 stud with a few washers help:).
It took me a month before I get up the courage to venture inside the transmission. The most I ever did was chanhed the trans. oil and replaced the filter.
Haven't drive the car much since it still need wheel alignment (Steering rack changed) and inspection and replace the heater core. The car has been sitting on the drive way almost two years now.
To Can someone explain this for me
