When cold the car is hard to stay running. Once it does start to idle on its own the idle is erratic. When you put it in gear you have to "2 foot" the gas and the brake to keep it running. It has a new fuel filter and good gas in it. The pump and sock were replace a year ago. The injectors are reman bosch's installed last year. I put a gauge on the fuel rail, it is around 36 and has held between 36 and 32 when sitting for 24 hours
After the car is warm these symptoms no longer happen with the exception of a higher than normal idle. The tach doesn't work so Im not sure what the idle is but to guess I would say around 1200 rpm's but is pretty much smooth.
Thanks for the quick response guys!! As you guys suggest I will change the temp sensor. Where is is located???
Yes I did a basic tuneup before last summer.
plugs
MSD wires
Cap
Rotor,
fuel filter.
I have checked for vacuum leaks but haven't found any.
Check your FSM. If you don't have one, you need one.
Look under your TB. It looks kind of like a spark plug with a dual wire connector. Put on a socket and loosen it. If you work real quick (real quick) you can swap it with loosing a minimal amount of fluid.
