Tire Balance or?
Old Dec 12, 2017 | 05:17 PM
81c3's Avatar
81c3
Default Tire Balance or?
86 Coupe 35,600 miles base suspension
Ok so I just last week had a 4 wheel alignment done.
All my shocks are new Bilsteins.
I have checked and double checked wheel bearings, all front end parts for wear and movement... there is none anywhere!
Tires are new looking but 6 year old BFG's
All 4 wheels/tires are Road Force balanced
Wheels torqued to 100 lb/ft
Rotor and wheel mating surfaces are clean
I cant seem to get rid of a vibration in the steering wheel for the most part...but I can also feel it in my butt.... at about 62 to 75 ish...
I have brand new rear wheels & tires out back 315/35/17
Fronts are 245/45/17
I jacked the car up and spun the front wheels checking for a bent rim or out of round tire....Rims look true. I did notice a little "hop" on the front left tire... I swapped a rear(the 9.5 245/45/17 that was on the rear) to the FL position and the vibration is still present.
Im down to thinking it might be the steering rack (it does display some light morning sickness) or tires even though they appear new.... I was going to buy 275/40/17 as replacements....
ANY ideas?
Thanks Guys!!
Old Dec 13, 2017 | 10:26 AM
RtStuf's Avatar
RtStuf
How long have you owned the car?
Always had vibration? If not, when did it start?
Doubtful steering rack at 36000 mi - any accident history?
Belt separation in tire?
Wheel out of round? - bought aftermarket wheels, had vibration - out of round was not found until third Roadforce technician found inside of wheel was out - not all technicians know what they are doing even though they have the equipment. Good luck finding problem.
Old Dec 13, 2017 | 01:45 PM
Churchkey's Avatar
Churchkey
Use a dial indicator to check the wheels on the car for lateral & radial run out. Check both outside & inside rim lips = 4 checks per wheel. Chevy wants .030 max run out in any direction.
Lateral run out can often be reduced / eliminated by indexing the wheel on the hub. Clock the wheel one lug stud @ a time then indicate, locate the wheel @ the point of least run out. Mark a wheel stud & the wheel for correct reassembly anytime a wheel is removed.
If more than .030 radial or lateral run out replace the wheel.
BTW Had vibs on my 89, had road force balance + checked wheels as above the cause was an out of balance front rotor.
Old Dec 13, 2017 | 09:07 PM
gerardvg's Avatar
gerardvg
ANY ideas?
Thanks Guys!!
Vibration through the wheel would be caused by out of round tires, buckled rotors or bad wheel balance.
You would be surprised the amount of tire manufacturing defects, most road cars will have soft suspension so you wont notice.
On a Corvette well that's another story, you can run over a coin on the highway and know of its heads or tails. an out of round tire or tread mold defects will shake the car like crazy.
Perhaps get them balanced elsewhere and ask they check the tires for high spots, good luck.
Old Dec 13, 2017 | 09:17 PM
81c3's Avatar
81c3
I just ordered a new set of 275 40 17 for the fronts just to eliminate the possibility of the 6 year old tires having being the cause. I wanted to have the rears and fronts match tread pattern anyway.
I have 4 wheels to choose from so I can have the shop pick the 2 best rims to mount the new tires on to. Typically the ones with the least amount of weights I suppose would be the best choices. I noticed 2 of mine took only one or two 1/4 oz weights and two took quite a bit more..
Old Dec 13, 2017 | 09:19 PM
81c3's Avatar
81c3
I thought about the rotors being the issue as well.... I bought new tires and if that doesnt do it, I will think about rotors next... I dont have a dial indicator unfortunately....
Old Dec 13, 2017 | 09:30 PM
81c3's Avatar
81c3
Ive only had it since about April.... no accidents on Car Fax anyway.... but the alignment tech said it all looked good as far as that goes.... I hear ya on the Chinese junk wheels... I could only find the ZR-1 17X11 +36 mm in a Chinese brand.... On the RFB machine.... I found that ironically enough, the local Ford dealer has a RFB machine as well as Big O tire which was where I was going....
Old Dec 14, 2017 | 11:04 AM
383vett's Avatar
383vett
Wait until you get the vintage tires replaced and go from there. Most likely they are the culprit.
To Tire Balance or?
