Crossfire Injection Fuel Lines
Old Dec 19, 2017 | 05:47 PM
quadracerx's Avatar
quadracerx
Default Crossfire Injection Fuel Lines
I need to make new "crossover tube". The one that connects the two throttle bodies... My car is not available to look at so I am coming here for some help...
What size is the crossover tube tubing?
What size and thread are the connectors?
Are these connectors female or male?
Thanks in advance for your help...
Steve
Old Dec 19, 2017 | 05:58 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Are you talking about the throttle linkage? Or the fuel line?
Old Dec 19, 2017 | 07:05 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Look on Ebay. There are plenty of factory (used) units.
Old Dec 19, 2017 | 07:20 PM
pezter22's Avatar
pezter22
This is something I have always planned on doing. It's too bad that the Crossfire Injection website (makers of the Renegade intake) didn't still produce the fuel line with the pressure gauge.
They list it with this info.
"Custom bent 3/8 316 polished stainless tubing, -6AN fittings, fuel block and 15psi gauge."
Small photo is from the Crossfire Injection website. The other photo is something I found in the internet of something I was planning to do.
http://www.crossfireinjection.net/catalog.htm
Old Dec 19, 2017 | 09:50 PM
84 4+3's Avatar
84 4+3
Corvette central also sells them. When mine cracked I ran a 5/16 hose on two barbs with clamps for a month or so. For that short run 5/16 is plenty. Factory is 3/8. I want to say I used a 5/16 barb on a 1/2" fitting with the flare on the end to seal on a compression style seat, the one in the throttle body base. I think the thread pitch npt... it may have been 3/8. Bought the parts at a local store as it was an emergency. That's also how I test my fuel pressure now.
Old Dec 19, 2017 | 10:05 PM
PatternDayTrader's Avatar
PatternDayTrader
So is that quadracerx as in Suzuki Quadracer ? or your racing quads in between Corvette repairs, or both ?
Old Dec 22, 2017 | 04:36 PM
corvettenorway's Avatar
corvettenorway
that internett photo is pics of mine ...more pics in my crossfire album
Old Dec 24, 2017 | 01:24 AM
Hot Rod Roy's Avatar
Hot Rod Roy
Originally Posted by 84 4+3
I think the thread pitch is npt... it may have been 3/8.
Definitely not NPT. Look at the fittings on that lower photo. The ports in your throttle bodies are 3/8" female flare. Using NPT threaded fittings into flare threads will leak, and will damage the threads in your throttle bodies. NPT threads are tapered, and flare fitting threads are not tapered.
Old Dec 24, 2017 | 05:23 AM
WVZR-1's Avatar
WVZR-1
The lines themselves I always thought to be 3/8 tubing so the fittings would be 3/8 INV FLARE which would be a 5/8-18 thread and on the tubing MALE.
To confirm you just buy at any auto parts store a 3/8 INV FLARE nut and try on your car.
AS HRR mentioned there is NO NPT - NONE - 0
A quick confirmation I'd think for tubing size etc would be to try a 5/8 open end on the fitting. If 5/8 fit that I'd think would confirm 3/8 tubing and the 5/8-18 thread OR a 3/8 open end on the tubing. Maybe both if you're a doubter!
Old Dec 24, 2017 | 08:29 AM
yd328's Avatar
yd328
You can take the tube off and bring it to a local auto parts store, such as NAPA. They should be able to confirm the size for you.
Gary
Old Dec 24, 2017 | 08:50 AM
84 4+3's Avatar
84 4+3
My bad. I just walked out to the garage since I'm home from school now. It's not even close to npt. There is an npt fuel line fitting in the box though. I don't have the box for the adapter I have anymore though. I was right about the flare end, it has the female side. Between 4 boats and 3 cars one of them has a damn 3/8 npt line on it lol.
Old Dec 24, 2017 | 01:29 PM
WVZR-1's Avatar
WVZR-1
Gary
That seems counter productive. Why would you disable the car just to check? Ain't no need.
To Crossfire Injection Fuel Lines
